05-15-2018, 11:10 PM | #1 |
Rock Crawler Join Date: Apr 2017 Location: US
| Servo heat
I have a two speed transmission on my project. Been playing with the endpoints to make it shift properly and not overextending the throw in either way. I get no buzzing, humming or vibrating coming from the servo(a good thing), seems to be working correctly. But for some reason the servo heats up pretty fast, is this normal? I don't think so, maybe I'm wrong. The steering servo is perfectly fine, no problems at all with it.
05-15-2018, 11:58 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: Servo heat
If you're running a BEC, make sure that the output voltage is set low enough for the servo. Otherwise, what two-speed setup? Servo? Aforementioned BEC or ESC?
05-16-2018, 01:57 AM | #3 |
| Re: Servo heat
Guess I'm not paying attention to what I'm writing, ready to go home from work. I gave a rc4wd trailfinder2 with the stock 2 speed trans and a cc mamba x system with the internal 8amp bec set at 6v. Maybe I missed a step with the setup in the esc.
05-16-2018, 10:28 AM | #4 |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: Servo heat
What servo are you using? Analog or digital? Note that analog servos may overheat when plugged into a newer receiver.
05-16-2018, 10:40 AM | #5 |
| Re: Servo heat |
05-16-2018, 12:14 PM | #6 |
| Re: Servo heat
I'm thinking the over heating is caused by one of two things. Either the circuitry inside the servo is faulty or your end points are set a little too wide. I know you said you have adjusted the end points very carefully, so maybe the servo circuit board has a problem. My suggestion is to remove the servo horn and power up the servo a few minutes and see how warm it gets. If it gets hot when it isn't doing any work, you will know the servo electronics are the problem. If it doesn't get hot, connect the servo horn again. If it gets hot now, the servo is trying to move too far so turn down the end point some more. |
05-16-2018, 02:50 PM | #7 | |
| Re: Servo heat Quote:
05-16-2018, 05:07 PM | #8 |
Rock Crawler Join Date: May 2016 Location: SoWIs
| Re: Servo heat
It depends on the circuitry. Some will buzz with the slightest load while others won't buzz when near the stop point but still draw power. If HeyOkay's idea results in a warm servo then it might be bad, otherwise it's your endpoints.
Servo heat - Similar Threads | ||||
Heat Shrinking - Lighter or Heat Gun? (Is there a DECENT Cordless Heat Gun?) | MailManX | Newbie General | 22 | 01-30-2014 02:24 PM |
Servo Heat | RCchomp | Electronics | 12 | 12-12-2010 08:57 AM |
Servo Heat Sink for JR DS8711 | Flynfrog | Electronics | 5 | 06-05-2008 11:17 PM |
Digital servo heat? | Highmark | Electronics | 9 | 10-11-2005 11:30 PM |
Servo Heat Sink. | syco133 | Electronics | 6 | 08-11-2005 04:29 PM |
