06-06-2018, 10:54 AM | #1 |
Pebble Pounder Join Date: Feb 2017 Location: Canada
| FS it4 radio how to setup dig
edit: okay not that anybody cares but with a flysky it4s radio I got a moa dual esc setup working. it wasnt a super easy thing but messing around with mixes for long enough i got it. mix 1. throttle is master channel. channel 3 is slave channel. mess around with the sliders until you figure out how to mirror them properly. i think its just the offset slider. mix 1 is always on, do not toggle. mix 2 i make as rear dig. same as mix 1 except using the low and high side sliders i make it so channel 3 is always at zero no matter what throttle is doing. mix 3 i make as front dig. same as above except i make master and slave channel both throttle channel. this allows u to keep throttle channel at zero while channel 3 is still functional (mix 1 is always on, therefor channel 3 still works) mix 4 is like mix 1 except i make rear axle move at slower rate with the high side slider i think it was. i left low side alone so reversing is normal. going forward my rear tires are slower. mix 2, 3, and 4 are all bound to the toggle keys. easy. hopefully this shows up on google if anybody is searching. dual esc moa crawler with dig using a flyskt it4s. Last edited by JoelTGM; 06-14-2018 at 11:31 PM. |
FS it4 radio how to setup dig - Similar Threads | ||||
Thoughts on Flysky FS iT4 2.4Ghz 4CH Radio | Cason_Crawler | Electronics | 4 | 08-07-2015 07:29 PM |
radio & dig setup | Crawlininga | Newbie General | 5 | 06-23-2010 09:55 AM |
setup ch3 on sensor radio for dna dig | OFF ROADER | Electronics | 3 | 01-02-2009 03:48 PM |
brainstorm for simple 2 channel radio dig setup | TJeeperMan | Electronics | 10 | 10-20-2005 08:59 PM |
