10-14-2018, 06:41 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: canada edmonton alberta
| switching rotation
Have pn racing motors hooked up in a rocksta one spins backwards,so switched the wires around it worked but no reverse.Checked with stock motor no reverse.Must have blown something on the board,it was a made motors 70 turn armature,bb case and neo mags Must have buggerd up thinking switch the mags on the backwards motor will be good? of course new board.
10-14-2018, 07:13 PM | #2 |
| Re: switching rotation
the orientation of the + and - was the same as the stock motors
10-14-2018, 08:29 PM | #3 |
It is hard to tell what you are talking about, did you take a motor apart and change the magnets? or did you buy new motors to replace the old ones? If you bought new motors the amp draw must be in spec with the rocksta's ESC or it could burn up the ESC. I doesn't matter of you hook the polarity up to the motors backwards, they will just spin backwards, not burn up an esc. maybe rephrase your question if you need more help. |
10-14-2018, 09:20 PM | #4 |
Thank for the reply its a built motor armatures bb7 case and neo mags that I put together my self it has been done before with these and sould work.so all was hooked up as stock +- but the rear motor spun backwards.wireing was done the very same as stock. Switched the wiring on the back motor all went forward but no reverse. Check with stock motors no reverse must have fryer the board. But next board should I switch the mags on the back motor ?
10-14-2018, 09:32 PM | #5 |
Maybe the timing had something to do with it .these are 130 motors but with a 70 turn sould be even timing .but I wired the motors that was same as stock. And one turn backwards so the mags must be different placement,? D Last edited by chbronco; 10-14-2018 at 10:08 PM. |
switching rotation - Similar Threads | ||||
Motor Rotation | WranglerMan | RC4WD Trail Finder 2 | 3 | 03-10-2016 10:03 PM |
Help with correct rotation | Reaper66 | Newbie General | 12 | 02-09-2015 09:44 PM |
Reverse rotation | Straxus | Axial Wraith | 4 | 01-18-2014 09:45 AM |
Reverse Rotation | Indiglo5997 | Axial AX-10 Scorpion | 12 | 09-09-2008 11:13 PM |
help! rotation | hodges996 | Electronics | 2 | 11-01-2006 04:34 AM |
