Thread: TRX4 light kit help
Old 10-21-2018, 12:44 PM   #1
Default TRX4 light kit help
I’m trying to install a Bronco light kit onto a truck that no longer has its oem esc. The kit (which seems quite nice) is TOO plug and play. There’s a single conductor wire that plugs into the rx and a two conductor that plugs into the lead hanging out of the XL5HV, that I no longer have....
Does anyone know what the red single wire running to the rx is for?
Does anyone know what voltage is present at the lead on the XL5?
Thanks for any help!
Oh, and I AM running a BEC..
skybolt is offline   Reply With Quote
Old 10-23-2018, 08:12 PM   #2
Default Re: TRX4 light kit help
The JST plug is battery power into the 8028 light power supply, the red wire is a switch wire that turns the 8028 on and off with the ESC. You will need to provide an additionsal JST connector off the battery lead to power the 8028. The red JST connector on the original XL5 is just a tap off the battery voltage.
Inspector86 is offline   Reply With Quote
Old 10-24-2018, 04:41 AM   #3
Excellent!
Thanks!
TRX4 light kit help - Similar Threads
Traxxas TRX4 Bronco light kit kincer Electronics 4 10-21-2018 11:41 AM
In Stock - New MyTrickRC Attack LED Light Kit w/ 5" Light Bar for TRX-4 Defender! RPP Hobby RPP Hobby 1 10-11-2018 12:32 PM
Trx4 kit or trx4 sport mebeknob Newbie General 10 09-26-2018 10:38 PM
