11-29-2018, 12:39 AM | #1 |
| GT3C programming question
I need help setting up my GT3C with a new air boat model using a 3 channel RX and a non-reversing ESC. The ESC is a 30A brushless HobbyKing. The throttle is currently working as follows. At the full throttle position, the motor stops. In the neutral throttle position, the motor runs at 50% forward. At the reverse throttle position, the motor runs at 100% forward. Programming this in the GT3C has me confused and any help from someone familiar with a hacked GT3C would be greatly appreciated.
11-29-2018, 06:47 AM | #2 |
Rock Stacker Join Date: Jul 2018 Location: MN
| Re: GT3C programming question
Sounds like more of a ESC programming or setup issue than the transmitter. Unless you need to redo the initial hack startup calibration. Around the 56min mark: https://www.youtube.com/watch?v=fdy6...4hCo5A&index=4 |
11-29-2018, 08:17 AM | #3 | |
| Re: GT3C programming question Quote:
11-29-2018, 10:57 AM | #4 |
After thinking about it I think you guys are correct. I know that channel 2 needs to be reversed but now I need to find out how to calibrate the ESC.
11-29-2018, 05:18 PM | #5 |
Problem solved! I reversed the throttle channel and then found a youtube video which explained how to calibrate the HobbyKing ESC. Works normally now.
GT3C programming question - Similar Threads | ||||
flysky gt3c question | RJW | Electronics | 2 | 03-26-2017 05:59 PM |
Help! Programming Flysky GT3C to Warn Winch | cornbreadfarts | Axial SCX-10 | 0 | 02-22-2016 10:08 AM |
gt3c hack question | mark32 | Electronics | 6 | 03-28-2014 02:35 PM |
gt3c battery life question | boohoo | Electronics | 5 | 08-06-2013 04:51 PM |
bully moa with rocker II dig, gt3c hacked controller programming issues!! | rainonflames | Electronics | 0 | 12-20-2012 05:27 PM |
