Thread: Castle brushless?
Old 03-23-2019, 04:55 AM   #1
Default Castle brushless?
I'm think of getting a mamba x/castle 3800kv combo for an axial bomber. I gather that the mamba x esc is pretty sweet bit how are the castle motors? Would I be better off just buying a separate motor? If so what are the recommendations? Used primarily for bashing.
Sent from my ONEPLUS A6013 using Tapatalk
cfritznewton is offline   Reply With Quote
Old 03-23-2019, 05:18 AM   #2
Default Re: Castle brushless?
I had the castle slate 3800kv. Things a powerhouse in an scx10 so id imagine itd be perfect for a bomber. Just remember to set the motor temp cutoff for 180*F. Motors waterproof and is a beast in the mud. And itll handle 2-4s batts
Sent from my LG-M703 using Tapatalk
jokersinsanity is offline   Reply With Quote
Old 03-24-2019, 01:09 AM   #3
The castle motors are great for bashers. Like said above, set the temp cutoff for no higher than 180.
Sent from my Pixel 2 using Tapatalk
brimdogg is offline   Reply With Quote
Old 03-24-2019, 03:09 PM   #4
Another option is to get a slower motor an up the voltage. Castle slate motors are max 100000rpm
Voodoobrew is offline   Reply With Quote
Old 03-24-2019, 07:24 PM   #5
wyd
The Mamba X is one of the most versatile esc's on the market from crawling, bashing , 1/10th and 1/8th scale racing. I run the Mamba X in my 1/8th buggy for 2 years now wit zero issues on 4s lipo and it's a beast. Combo the Mamba X with the Slate 3800 and you will have a fantastic combo. 4 pole power along with the Mamba X will give you unlimted versatility.
wyd is offline   Reply With Quote
Castle brushless? - Similar Threads
no power..castle brushless xiteamxi Electronics 6 03-12-2012 09:01 AM
