04-01-2019, 08:07 PM | #1 |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
| Motor wiring?
Does anyone have a suggestion on where I can get good wiring for motor leads? I can get 12 ga stranded wire anywhere but its usually pretty stiff.
04-01-2019, 08:10 PM | #2 |
Pebble Pounder Join Date: Jan 2018 Location: Northeast Iowa
| Re: Motor wiring?
tekin sells some pretty nice wire. called flexwire. https://www.teamtekin.com/shop/index...product_id=101 |
04-01-2019, 10:29 PM | #3 |
| Re: Motor wiring?
This suff is the most flexible 12ga wire I have ever run across. https://www.rpphobby.com/product_p/wsd1410.htm |
04-02-2019, 03:56 AM | #4 |
| Re: Motor wiring?
I just order wire from ebay thats silicone coated, the stuff i got was good, is there bad silicone coated wire?
04-02-2019, 06:13 AM | #5 | ||
| Re: Motor wiring? Quote:
Cheap stuff isn't as good as good stuff. You can get crappy insulation and less flexibility with the cheap stuff. I can't speak about conduction and resistance. | ||
04-02-2019, 06:49 AM | #6 |
| Re: Motor wiring?
I like the TQ wire 13G stuff when I actually have to buy wire. It is about the size of most 14G wire on the outside but about the same as 12G wire on the inside. https://www.amainhobbies.com/tq-wire...qw1331/p238324 Most of the time, I end up using the spare wires that get horded away because they may be the right size one day. |
04-02-2019, 08:06 AM | #7 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
| Re: Motor wiring? |
04-02-2019, 08:40 AM | #8 | |
04-02-2019, 09:45 AM | #9 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: Motor wiring?
How much flexibility is really necessary? In most cases the ESC and motor are close to each other, if not right next to each other, so the wire doesn't need to snake through a labyrinth of obstacles. Throw a little heat shrink tubing over a coat hanger and it'll work. If you want to pay a premium for the fancy stuff with the silicone jacket, that's good, but if not, any stranded 12 AWG wire will do. The electrons won't care. |
Motor wiring? - Similar Threads | ||||
Need Motor wiring help please | flip3d | Axial XR10 | 4 | 06-22-2012 09:29 AM |
Motor wiring? | asian195 | Electronics | 3 | 10-02-2011 11:56 PM |
Motor wiring | offroad1911 | Electronics | 4 | 06-02-2007 03:27 AM |
Motor Wiring | Norcal crawler | Newbie General | 23 | 01-31-2007 11:05 PM |
Motor wiring | jeep_boy02 | General Crawlers | 5 | 07-17-2004 02:28 PM |
