Thread: DX5c Newb Question
Old 04-09-2019, 09:08 PM   #1
Default DX5c Newb Question
When assigning an AUX port to a button, what does the settings Cyclic and Momentary mean? Also Linear?
2nd question. I have two speed tranny with low, neutral, and high. What settings would I use for that AUX port to shift between the three modes? I assume 3 position switch, but what else?
Thanks!
tphjill is offline   Reply With Quote
Old 04-09-2019, 09:20 PM   #2
Default Re: DX5c Newb Question
Thanks!
Cyclic means as you press the button it cycles through the positions set for that channel.
Momentary means it will go back to starting position when you release it.
Not exactly sure on the linear.
Yes the tranny will need a 3 position setup.
Sent from my Pixel 2 using Tapatalk
brimdogg is offline   Reply With Quote
Old 04-10-2019, 11:49 AM   #3
Linear means it has like 100 steps instead of 3. Would be good for using the aux wire with drag brake.
Generally you would leave momentary off for a 2 speed transmission or aux wire. You could use momentary with a winch controller.
Voodoobrew is offline   Reply With Quote
Old 04-10-2019, 12:07 PM   #4
You'll need to use cyclical and 3 position switch for your (3 position) 2 speed. Your AUX travel will set the low and high and the AUX sub trim will be the value for neutral, though this order will depend on the order your tranny shifts in.
HumboldtEF is offline   Reply With Quote
DX5c Newb Question - Similar Threads
Dx5c question AWraith build Electronics 11 07-09-2021 11:23 PM
Newb question rcjeeper Venom Creeper 13 06-02-2010 08:39 PM
not a newb but have a question of newb stature Brandon88 Electronics 11 04-14-2010 08:53 PM
Newb question to beat all newb questions vinster888 Newbie General 3 12-29-2009 07:24 PM
