Thread: Under powering steering servo
Old 08-28-2019, 01:44 PM   #1
Default Under powering steering servo
I just upgraded my crawler to a savox SC-1258TG. Before I upgraded I was having issues turning the wheels when in tight spots, so I upgraded. I still have this issue with the savox, but I am noticing my led lights are dimming when I am in those tight spots. Will a upgraded battery solve this?
Vtolds is offline   Reply With Quote
Old 08-28-2019, 01:58 PM   #2
Default Re: Under powering steering servo
Sounds like you need an external BEC. What ESC do you have?
Col_Sanders is offline   Reply With Quote
Old 08-28-2019, 02:01 PM   #3
Get a HeyOK No-Brainer adjustable BEC - no soldering needed!
https://www.amainhobbies.com/heyok-p...nbradj/p521836
Bring your servo back to life...
durok is offline   Reply With Quote
Old 08-28-2019, 02:11 PM   #4
It is a Hobbywing Wp-1625 Brushed, so its low end for sure.
Old 08-28-2019, 02:38 PM   #5
Ouch.... BEC Output: 1A/5V (Linear Mode)
You really want about 3A output for a decent servo, the HobbyWing 1080 WP ESC is very popular because it puts out that much and is only a $40 speed controller.
It's also programmable (comes with a programming box) and waterproof.
Could cut your losses and just upgrade the ESC and not need a BEC.
https://www.rpphobby.com/product_p/hwi30112750.htm
Old 08-28-2019, 02:44 PM   #6
I would rather just upgrade the esc than add something. Thank you for the recommendation.
Old 08-28-2019, 02:48 PM   #7
Good idea - I've got the HW1080 in a TRX-4 and an Ascender, excellent ESC - it's extremely popular in the rock-crawling world.
That HW1625 you have is meant for smaller than 1/10th-scale RCs, such as 1/16th or 1/18th scale.
Nothing wrong with it for what it is, just going to struggle being used for larger applications.
Old 08-28-2019, 02:51 PM   #8
Technically it is a 1/12 scale I have.
Old 08-28-2019, 03:37 PM   #9
The HW1080 is still the one I'd go for, if you are having any servo brown-out issues with your current ESC.
Old 08-28-2019, 03:43 PM   #10
On the 1080 WP ESC should I get a 60 amp version or 80 amp version. I found the 80 amp version for less than the 60 amp.
Old 08-28-2019, 03:58 PM   #11
Quote the full model name or provide a link, please - there is only one version of the Hobbywing QUICRUN WP 1080 ESC:
https://www.hobbywingdirect.com/prod...nt=26223842568
There is a HW QUICRUN 1060, totally different ESC:
https://www.hobbywingdirect.com/prod...iant=753399705
Either one would work for a typical 1/12th crawler, but the 1080 is completely programmable with an easy to use (and included) programming box and is more powerful - a better purchase in my opinion, as you can move it to a bigger and heavier crawler someday.
Old 08-28-2019, 04:01 PM   #12
My mistake especially since I cant find it now. Just an 80 amp.
Old 08-28-2019, 04:46 PM   #13
I just ordered the 1080 ESC, should be just what I need. Unfortunately I probably ordered that Savox Servo for no reason. Well at least I got spares.
Old 08-28-2019, 05:00 PM   #14
It's ALWAYS handy to have a spare servo - they are the one electronic part that will give out with no warning, right when you've arrived at the trailhead for a day of rock crawling!
Bring the spare with you whenever you go...
Under powering steering servo - Similar Threads
Question about powering a TRX-4 steering servo upgrade. secondcircle Newbie General 4 01-05-2018 01:58 PM
Powering Receiver/Servo Lukefalls Newbie General 2 01-17-2010 12:32 AM
powering a 3 racing winch , servo & receiver Badd Electronics 1 07-28-2009 05:31 AM
BEC install for powering servo question? Wild Snapper Electronics 7 11-06-2008 11:27 PM
Powering a servo board converted to micro esc nascarkeith Electronics 19 06-07-2008 01:46 AM
