12-06-2019, 07:27 PM | #1 |
Rock Stacker Join Date: Oct 2019 Location: Omaha
| Stripped wires on Savox 1210sg
So I finally decided to upgrade my cheap 20kg servo on my Gen 8 to a Savox 1210sg. The opening to actually fit the servo through the frame is very tight. I had to pull the wires through to get the servo wires to the top. In doing so I stripped two wires that lead into the servo. They are exposed and touching together now. Any ideas on how to fix this? I thought about putting electrical tape but again there are a red and a blue lead that are touching next to each other and exposed. Any help would be appreciated! |
12-06-2019, 07:37 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: Stripped wires on Savox 1210sg
its easy to pop open and just cut them off and resolder. Thats what I would do. Is it literally into the the rubber grommet where stripped? If not just spread and tape them |
12-06-2019, 07:55 PM | #3 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
That's crap advice, it's pretty damn hard to get at the solder pads without destroying a 1210.
12-06-2019, 08:14 PM | #4 |
| Re: Stripped wires on Savox 1210sg How so? You mean as in losing its waterproof capabilities? Maybe so, but a little shoegoo could help if you were that worried about it. If the wires are stripped into the case what would you suggest then, as you clearly have the ins and outs of this servo? Assembly and components are the same as a standard servo, and if hes capable of soldering this is a very simple task. |
12-06-2019, 08:28 PM | #5 | |
| Re: Stripped wires on Savox 1210sg Quote:
12-06-2019, 09:00 PM | #6 |
Yes, except mine was a completely smoked literally charred board (came used in a rig ). It is very standard, nothing special about it. Remove top and bottom screws, desolder pot, remove motor screws pull out board, repair wire and reassemble. In all fairness, I did not reassemble but not sure what could have gone wrong. Would take all of a 15 min to repair. However,, after reading OP post again, I think they are stripped outside the case anyways, so I would just tape it. |
12-06-2019, 10:49 PM | #7 |
Rock Stacker Join Date: May 2019 Location: Boyertown Pa.
Try liquid electrical tape. You should be able to apply a small amount between the individual wires. The can will come with a brush inside the lid. Try applying it with a Q-tip. Good luck!
12-07-2019, 05:43 AM | #8 |
| Re: Stripped wires on Savox 1210sg |
12-07-2019, 09:08 AM | #9 |
12-10-2019, 02:52 PM | #10 |
So did you try this yet?
12-11-2019, 10:19 AM | #11 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
Yup, as was mentioned this is the perfect application for liquid electrical tape (and pretty much the only way that stuff should be used)
Stripped wires on Savox 1210sg - Similar Threads | ||||
Savox SW-1210SG parts | JoeConti | Electronics | 5 | 03-04-2019 07:52 AM |
3A BEC for Savox 1210SG | obadvw | Electronics | 5 | 11-08-2018 10:20 PM |
Savox 1210Sg seems to be weakening... | pearing | Electronics | 10 | 10-28-2018 12:39 AM |
