Thread: Mamba Micro with HH Stubby 2700kv
Old 12-15-2019, 10:18 AM   #1
Question Mamba Micro with HH Stubby 2700kv
looking feedback regarding a the Mamba Micro paired up with a HH Stubby 2700kv motor
rig weights aprox 6.3-6.5 pounds
will the micro handle ir or a Mamba X is more suited for the 2700kv
thank in advance!
Jamifra is offline   Reply With Quote
Old 12-15-2019, 10:57 AM   #2
Default Re: Mamba Micro with HH Stubby 2700kv
I've been running the MicroX and 2700kv stubby in a couple cars (8.3lb Wraith and now ~6lb Capra) for the last year and haven't had any issues. The Wraith is geared pretty low at 65:1 so the small motor/esc didn't have to work too hard. I can still stall it when the 2.2"s get in a bind, but I'd say it's totally adequate for a sub 8lb crawler on 1.9"s or 6lb-ish on 2.2"s.
TheLetterJ is offline   Reply With Quote
Old 12-15-2019, 12:02 PM   #3
Sw4 is a great esc with that motor as well. But youll need a bec to power a good servo. Still a cheaper option than the mamba X. Dont overlook the revolver. Its a amazing motor..
pyroM!KE is offline   Reply With Quote
Old 12-15-2019, 12:38 PM   #4
The SW4 is a non sensored ESC. You will want the Micro X or Mamba X with this motor.
The 2700 is about micros max from what ive found. You will need stick without your lowest gearing option most likely. I ended up going to the 2200 as the esc was just getting a tad warm with the 2700. Still plenty of punch and very cool temps.
Joshs4x4toyz is offline   Reply With Quote
Mamba Micro with HH Stubby 2700kv - Similar Threads
Mamba Micro X and HH Puller Pro Stubby 2200 Angus_Beef Electronics 122 12-05-2017 01:30 AM
Mamba Max Pro with HH 2700kv Waterproof Motor Issue malickie Electronics 13 03-23-2017 07:16 AM
Mamba Micro (Bullet Connectors) Holmes 540 Stubby SteaminPete Newbie General 7 03-17-2016 02:26 PM
