02-01-2020, 10:01 AM | #1 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| Cross rc light module causes servo glitches
I wired up my bc8 and everything is working with one exception. It appears something about the lighting module, which gives you turn signals, causes the steering servos to glitch. Here is a video of it happening. https://youtu.be/2YyHOEci0AI When I disconnect the light module and run the servos directly to the RX they work fine. Anyone else use a cross rc light system and have issues? Any recommendations of things I could do to fix the situation? |
02-01-2020, 03:34 PM | #2 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
| Re: Cross rc light module causes servo glitches
I can't see if you are running a separate BEC in the video. If the servos are plugged in to the receiver, you may be short of amps required to operate the servos. I had a similar issue on a 4WS setup and adding a BEC to power the servos sorted things out nicely. Also seems like the more throttle, the worse the glitching gets. Again possibly an indication of a power supply issue. You might try disconnecting 1 of the servos and do the same test you did in the video. 1/2 the power draw and if that works better it would suggest a separate BEC is required. |
02-01-2020, 05:42 PM | #3 | |
| Re: Cross rc light module causes servo glitches Quote:
As far as BEC I'm not running one because I'm using holmes shv500v2 servos powered directly off the battery. Since the problem doesn't appear when I don't have the light module connected in. Could signal noise come from a light module? It gets its power from the receiver so I wouldn't think that would happen. | |
02-01-2020, 07:10 PM | #4 |
Quarry Creeper Join Date: Dec 2019 Location: Woodstock
I have the Cross light module as well, not have not seen that problem, Not sure what paper work you got with it. Cause most times these adds on do not come with any useful instruction. You are welcome to what I have, see if you can spot something. Futaba TX RX pep Last edited by JacktheRipper; 02-01-2020 at 07:18 PM. |
02-01-2020, 07:23 PM | #5 | |
02-01-2020, 07:40 PM | #6 |
Hard question had to go look LOL ESC 1030 servo ECO power 110T pep |
02-02-2020, 12:08 AM | #7 |
Another thought. Because you are running the servo with direct battery power, I am assuming you only have the white signal wire from the servo connected to Ch1 of the light controller. Is the wire from the receiver to Ch1 just the signal wire or do you have the + and - wires connected as well? Might only need the signal wire from the receiver to the light controller. Might need the ground wire as well but maybe not the power wire. Couple of things to test . . . . . . .
02-02-2020, 12:17 AM | #8 | |
RCC Addict Join Date: Jun 2016 Location: Germany
My HV500, direct powered by the battery, has the same issue you mention, but only on one Lipo Pack with a low C-Rating. If I use my higher C Lipos the issue is gone. | |
Cross rc light module causes servo glitches - Similar Threads | ||||
TRX-6 Light Module Questions | hibbs | Electronics | 2 | 04-19-2020 10:33 AM |
Bad servo cause Glitches?????? | meanbgreen | General Crawlers | 5 | 12-20-2011 02:51 PM |
Dig Servo glitches under power!!! | mudboger07 | Electronics | 3 | 01-27-2009 08:52 PM |
new MG945 servo, now it glitches | jbrandt | Electronics | 2 | 10-23-2007 12:14 PM |
hitec 5995 servo noisy glitches? help | toy4crawlin | Newbie General | 18 | 02-14-2007 09:13 AM |
