03-28-2020, 02:12 PM | #1 |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
| Tekin FXR
Hello folks... I have a Tekin FXR that I purchased some time ago for a shafty build that I never got round to... Thought about using it in the Capra I'm building currently but will be running 3s. Now, in the manual that comes with the unused unit it says 2s, but if I go on Tekins' website it says I can use 3s so long as I don't go above 30t. My question is two fold, a. waddayareckon re 3s? and b. Will a Holmes 5 slot 16t motor be too much even though theoretically the numbers should be fine.... Thanks |
03-28-2020, 04:02 PM | #2 |
| Re: Tekin FXR
A Holmes 5-slot 16T motor should be fine on 3S with the FXR. I have a BRX and I'm going to be running the exact same. I checked with Ty of Tekin and he said it will be fine. You could reach out to him to be sure. Here's his profile: http://www.rccrawler.com/forum/membe...ekin-17800.htm |
03-28-2020, 04:16 PM | #3 |
| Re: Tekin FXR
Thanks man. Have pinged him a pm. My main concern was if Tekin had updated the FXR since I purchased mine leaving the potential that mine will just fry on 3s. I will also have to use a BEC with the FXR which partly voids its weight saving. The only other unit I have in stock currently is a HW1080 which was due to go on something else and what I remember of my last drives with an FXR, they should be a bit smoother than the 1080.... |
03-28-2020, 06:56 PM | #4 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: Tekin FXR
I think (as I can't find the manual), the the FXR has a 35 turn limit. but I have run a 30 turn Tekin handwound motor for a long time with no problem on 3s.
03-29-2020, 07:05 AM | #5 |
Newbie Join Date: Jul 2018 Location: Australia
| Re: Tekin FXR
I was in the same boat when i bought my FXR 30 turn combo, contacted Tekin some time back ( few years) and the reply I got was as long as I run an external BEC it would be fine on 3s . Also as a coincidence I was on their website yesterday to see if they still made them as I wanted to buy another one and it says that you can use 3s if you use a 30 turn or higher motor and in small print with an asterisk it says on 3s you must use an external BEC . I probably still would confirm with Ty if you’re unsure. |
03-29-2020, 09:21 AM | #6 | |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: Tekin FXR Quote:
03-29-2020, 12:35 PM | #7 | |
Thanks folks, think I'll solder it up and see... | |
Tekin FXR - Similar Threads | ||||
Mamba Max , Tekin FXR or Tekin FXR PRO? | TheHeadHunter | Electronics | 21 | 06-21-2012 08:15 AM |
Tekin FXR and FXR-pro ESCs in stock | JohnRobHolmes | Holmes Hobbies | 35 | 09-17-2009 09:40 PM |
