Thread: Help with servo and ESC plugs
Old 05-16-2020, 07:34 PM   #1
Default Help with servo and ESC plugs
I need some help figuring out how to plug my electronics into my airtronics/sanwa receiver. I have 2 spectrum servos with yellow/red/brown wires, a hitec servo with yellow/red/black wires, and a HW ESC with all black wires. All the plugs can be inserted into the receiver either direction and im trying not to fry anything lol. Picture is what I'm working with.
josh9mile is offline   Reply With Quote
Old 05-16-2020, 07:47 PM   #2
Default Re: Help with servo and ESC plugs
black or brown wire goes to the outside edge of receiver. for the all black plug simply put it in so the open side of the pins faces the same way as the rest of them
Sent from my SM-G965U using Tapatalk
midwest_rippa is offline   Reply With Quote
Old 05-16-2020, 08:30 PM   #3
Thank you!
Old 05-16-2020, 08:35 PM   #4
No problem, anytime!
Old 05-16-2020, 08:50 PM   #5
For future reference, you're not going to fry anything if you accidentally plug a servo or ESC in backwards to your receiver. I've been doing RC for 30 years and still do it almost every time I have to plug into my receiver just because I'm a dumbass and can't remember which way it goes.
Just don't plug your ESC into your battery backward. That will have a much worst outcome...
jmitchell13 is offline   Reply With Quote
Old 05-17-2020, 08:36 AM   #6
For the most part, the light wire goes to the center of the RX, the darker wire to the outside. Never seen a RX lead with all of the same colors, that is a little weird.
Wire colors aside, those connectors are actually keyed to help you. If you look at the connector, one side has a little bevel to it, this matches up with the bevel on the RX plug.
Greatscott is offline   Reply With Quote
Old 05-17-2020, 08:42 AM   #7
May vary from various receivers ... I fried 2 GR3E from plugging the ESC backward ...
tuxstang is offline   Reply With Quote
Old 05-17-2020, 10:07 AM   #8
the all black hw plug should have a very very light marking on the plug, identifying - + and signal.
magic_yeti is offline   Reply With Quote
Old 05-19-2020, 10:50 AM   #9
I have a Savox monster with all black wires, they are marked -+S in the plastic. Can't see them on this one though, might just be the camera. On your receiver, the open copper part of the plugs face the antenna.
Voodoobrew is offline   Reply With Quote
Help with servo and ESC plugs - Similar Threads
Servo plugs without tools Orph3o Electronics 9 11-10-2012 03:19 PM
servo plugs???????? captain.roche Electronics 11 11-06-2010 02:09 AM
Are double male servo plugs available? shelljeep Electronics 3 10-21-2010 08:38 PM
banana plugs and esc slayer 88 Electronics 6 08-27-2009 09:56 PM
