Thread: will it work?
Old 08-18-2007, 08:26 PM   #1
Default will it work?
will it work in my super? yes? no? im running 2 945 mg servos and it weighs about 10-13 lbs http://holmeshobbies.com/product.php...4&cat=4&page=1
Mikekx65 is offline   Reply With Quote
Old 08-18-2007, 08:56 PM   #2
I don't know what that motor weighs, john can tell you but I think you will need a bigger esc and motor to pull a 13 lbs truck with one motor, it would probably work in a clod though. Get the quark, not the mamba.
Kamikaze is offline   Reply With Quote
Old 08-18-2007, 08:59 PM   #3
MODERATOR™
EeePee's Avatar
I think thats the 2 ounce GWS motor.
So the answer is, no, no chance in hell.
EeePee is offline   Reply With Quote
Old 08-18-2007, 09:38 PM   #4
2 oz???, not a chance, mabey 4 or 5 and a mamba max.
Old 08-18-2007, 10:19 PM   #5
Alright, thanks for the pointers. I Thought i could save a few bucks but i guess im back to plan A. What motor would you recommend for my rig? Brushless motor that is. will a crawlmaster do the trick?
Old 08-18-2007, 10:42 PM   #6
indeed!
smokinubyrc is offline   Reply With Quote
Old 08-18-2007, 10:46 PM   #7
TEAM MODERATOR
Reflection's Avatar
What kinda drive train/tranny you running?
IMHO,the crawl master is a great motor for a 2.2 and lightweight supers. My super is right at 12 pounds. It would probably pull it O.K. but would have to work at it. IMHO,a 3025-8 is a much better option for a heavier super class rig. The 3025-8 is a perfect motor for a super.....but your drive train better be stout. The 3025 will find any weak point and shred it to pieces.
I've got a crawl master in my 2.2 and it is PERFECT.
The set up I have.....in my 2.2 it's a Mamba 25/Crawl master. In my super,it's a Mamba Max/Hyperion 3025-8. Couldn't be happier with either set up. IMHO,the Mambas are THEE best ESC option out for crawlers. I don't think you can beat the performance/programming options they are able to do
Reflection is offline   Reply With Quote
Old 08-18-2007, 11:09 PM   #8
well as of right now my drive line is an e-maxx tranny locked in 1st ans revo shafts. Im getting a mamba max nothing will change that but im still open to motor suggestions.
Old 08-19-2007, 12:09 AM   #9
For that hevey a rig the bm16 would be perfect, ot the bm17 if your a little crazy.
Old 08-19-2007, 04:46 PM   #10
Since we're on this subject, any suggestions on what motor/esc combo would work well in a 18-20 lb. super 19" WB tuber rig with Kongs? (Twin Force tranny, Revo's & Twin Force axles with 4.3 helicals & spools.)
BeeRC is offline   Reply With Quote
Old 08-19-2007, 05:32 PM   #11
WOW 20lbs now thats a pig
Old 08-19-2007, 05:53 PM   #12
I just re weighed mine and its now 9.5 lbs. But i will be adding metal rod ends so that will add a lb or 2
Old 08-19-2007, 06:42 PM   #13
Default will it wo
Yeah, It's definitely a pig...a BIG pig. Anything with kongs on it ends up being a pig, plus this one runs heavy RC4WD Jumbo aluminum beadlocks which make it even heavier yet. BTW, this is NOT a comp rig.
Old 08-19-2007, 07:55 PM   #14
TEAM MODERATOR
Reflection's Avatar
Mamba Max/3025-8
I ran that in a 21 pound Twin crawler with 8 1/2" tall Frankenstein LST tires and it pulled it around.....no sweat. I'll see if I can find the video of it.....
Old 08-19-2007, 07:57 PM   #15
Where can i get this 3025-8 @?
Old 08-19-2007, 08:01 PM   #16
TEAM MODERATOR
Reflection's Avatar
Again,No question,Mamba Max/3025-8
The smaller motors might pull it O.K. but it might be pushing them a bit. There is no such thing as having to much power The 3025-8 will sling that rig around like a rag doll if set up correctly.
Like JRH's says.....gear down,volt up and you will see
The ONLY place to buy crawler electronics.....Holmes Hobbies. Click my sig
Old 08-19-2007, 08:04 PM   #17
Call me stupid but i looked through the motors and didnt see it. Am i doing somthing wrong here?
Old 08-19-2007, 08:10 PM   #18
A mamba max and a bm16/17 would be realy good for that much weight.
Old 08-19-2007, 08:14 PM   #19
Hey raptorman can you hit me up on aim (mikekx65173) Thanks
Old 08-19-2007, 08:21 PM   #20
TEAM MODERATOR
Reflection's Avatar
Well,he is probably out of them. This little jewel will be REAL close to the Hyperion 3025-8.....Scorpion 3020-14 If I needed a big outrunner,it'd be the one I'd buy. Looks like a jim dandy.
