Thread: Need help no power
Old 11-08-2007, 07:11 AM   #1
Default Need help no power
I'm having a heck of a time installing my MPI regulator.. I followed your write up on installing a MPI and I'm not getting any power. I'm using a Mamba Max with a crawlmaster and all I get is a red and green light blinking. I did it step by step and thats all I get. If anyone can help that would be awesome because I'm at a lost..I solder the one wire to the battery like the way in the post have it and took the red wire off the ESC and taped it back. I did everything in the write up..Just don't know what to do.. How To: Installing an MPI voltage regulator
If you could help I would be very greatful thank you...
Azcats1 is offline   Reply With Quote
Old 11-08-2007, 06:53 PM   #2
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Still no luck with this eh? Does the system work without the voltage reg? Could be a bum unit.
