Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Element RC 1/10 Enduro Trail Truck Sendero
Thread: Enduro, here we endurgo!
Old 07-14-2019, 02:19 PM   #21
Default Re: Enduro, here we endurgo!
Originally Posted by Fishcharger View Post
I do like the bumper shown in the pic there, not sure which brand/model it is though.
That looks to me like the stock Axial Deadbolt bumper.
GA Dawg is offline   Reply With Quote
Old 07-14-2019, 02:50 PM   #22
Gotcha. I’ll have to look and see if Werty Made or RC4WD make one.
Fishcharger is offline   Reply With Quote
Old 07-14-2019, 03:11 PM   #23
dezfan's Avatar
Looking good! Haven’t even had the opportunity to open the box on mine yet. 😠
dezfan is offline   Reply With Quote
Old 07-14-2019, 03:15 PM   #24
Well heck, get on it! Everything else should take a back seat once a new kit is in hand right
Old 07-14-2019, 03:39 PM   #25
dezfan's Avatar
Normally I would agree.
Just got notice my boy is being sent overseas to an undisclosed location for 6 months or more. 😐
Old 07-14-2019, 03:47 PM   #26
Hmm, well I’d say that definitely qualifies as a good reason to postpone a build. Best wishes to you and him.
Old 07-14-2019, 05:57 PM   #27
CODYBOY's Avatar
May god be with him, and we all praying he comes home safely!
Ernie
CODYBOY is offline   Reply With Quote
Old 07-14-2019, 08:04 PM   #28
Thank him for his service. I like to thank other service members. I know he'll be getting after it!
MaX-D is offline   Reply With Quote
Old 07-15-2019, 01:46 PM   #29
Found this interesting. Just about every rig I have has Incision links on it. Which has meant some tedious sore finger causing work. The link design here is basically exactly like the Incision links. Is putting grease on the metal threads a trick for easier rod end installs that I didn’t know about?
Old 07-15-2019, 02:50 PM   #30
Any input here? Seem to have about 2mm of travel in and out with the universal. Does that travel need to be present, or should I put a shim in to get rid of it. If so where would be the correct place to put the shim, between the hex and the outer bearing?
Old 07-15-2019, 03:08 PM   #31
Found this interesting. Just about every rig I have has Incision links on it. Which has meant some tedious sore finger causing work. The link design here is basically exactly like the Incision links. Is putting grease on the metal threads a trick for easier rod end installs that I didn’t know about?[/IMG]
Chapstick.
preferably straight off the stick, don't apply to lips then lips to threads. that's just a bad look.
then just put 2 drivers through the open rod ends and spin away. no reason to wear out your thumbs doing that.
Shinchu is offline   Reply With Quote
Old 07-15-2019, 03:19 PM   #32
CODYBOY's Avatar
Ok, this makes it so easy you won't believe it!!! I put a little machine wax on the threads and (drum Roll please) put the link in my drill, one of my drivers in the link end and run the in with the drill. Make sure you are at a very low speed on the drill. Run it down to the end of the threads, turn it around and put the link end the chuck and run the other one down. EASY PEASY!!!
Ernie
Old 07-15-2019, 03:21 PM   #33
^^^ From the master where i learned chapstick/machine wax
Old 07-15-2019, 04:46 PM   #34
Ha very good thanks. Great tips. I’d considered using my drill motor many times when nursing my callused finger tips. Just was concerned about damaging them, so never pulled the trigger, as it were.
Old 07-15-2019, 06:43 PM   #35
You need some end play, that sounds like more than normal, but a 5mm shim behind the pin, in front of the bearing,Traxxas rigs usually needed these , so I have some
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 07-15-2019, 07:18 PM   #36
Hang up and Drive
Awesome thanks man. Yep have some Traxxas 5mm shims in hand I will use. And ya thought the same, just seemed like a bit more play than I remember when building other kits.
Old 07-15-2019, 08:10 PM   #37
Do the axles butt in the center? If they do, a quick lap will solve that.
Im so used to axial slop, my VP’s were a dream fit wise, I should get to axles tomorrow evening when I will look and measure
Hang up and Drive
Old 07-17-2019, 03:36 PM   #38
Hang up and Drive
You end up getting to your axles yet? Interesting thing. I got all the “hard” plastic options when I ordered the kit. Minus the caster/steering blocks which came today. Once installed I’ve found there is now zero slop with the front universals with no shims
Old 07-17-2019, 06:18 PM   #39
I used the hard blocks, perfect fit also!
Hang up and Drive
Old 07-17-2019, 06:51 PM   #40
Hang up and Drive
Hell yeah awesome
Enduro, here we endurgo! - Similar Threads
What I'm doing to my ENDURO! CODYBOY Element RC 1/10 Enduro Trail Truck Sendero 98 04-10-2020 08:37 PM
Enduro Funduro Old n ratty Element RC 1/10 Enduro Trail Truck Sendero 3 07-07-2019 01:43 PM
kmc enduro? flat out Tires and Wheels 18 11-18-2012 10:59 AM
The 1/8 Wonder Enduro Race The Cow Non Crawler RC's 5 09-22-2010 03:47 PM
Enduro Cross twisted Chit Chat 7 02-05-2008 08:22 PM
