05-13-2020, 09:51 PM | #1 |
Newbie Join Date: Apr 2020 Location: Monroe
| Let's see those light kits!
I'll start... I used this kit from Amazon: https://amzn.to/3bqkafb Sent from my SM-G988U using Tapatalk Last edited by mys4.org; 05-13-2020 at 10:25 PM. |
05-13-2020, 10:04 PM | #2 |
Newbie Join Date: Mar 2019 Location: Altadena
| Re: Let's see those light kits! Sent from my iPhone using Tapatalk |
05-13-2020, 10:05 PM | #3 |
05-18-2020, 08:27 AM | #4 |
Newbie Join Date: Sep 2019 Location: Kent
05-20-2020, 05:52 PM | #5 |
Newbie Join Date: May 2020 Location: CZE
| Let's see those light kits! I知 sorry for off talk, but is it the ABS Jeep body?If so, could you share with us the bottom of this body? I am interested in similar ABS Jeep body (convertible one) and I wonder how much I must cut the interior to fit it on the chassis. Thank you. Sent from my iPhone using Tapatalk Last edited by kejmildoh; 05-20-2020 at 05:56 PM. |
05-20-2020, 07:23 PM | #6 | |
| Re: Let's see those light kits! Quote:
Are you running your PitBull Growlers backwards for some reason? | |
05-20-2020, 07:48 PM | #7 |
Quarry Creeper Join Date: Aug 2009 Location: orange county
I run mine the same way. Backwards seems to bite better for me. I知 still up in the air if I like mine
05-21-2020, 12:11 PM | #8 | |
At first I was the same way but they certainly get better the more you use them. That said, I'll likely go Proline the next time around as it seem to be the best, I just didn't want to get new wheels. Last edited by mys4.org; 05-21-2020 at 12:26 PM. | |
05-25-2020, 12:02 PM | #9 | |
Hi yes it is a hardbody I値l grab a picture for you Sent from my iPhone using Tapatalk | |
05-25-2020, 12:06 PM | #10 | |
05-25-2020, 01:09 PM | #11 |
I went simple and rolled my own... I used 3 and 5mm LEDs from Common Sense RC, they come prewired with a load resistor. Untitled by Scott O, on Flickr Untitled by Scott O, on Flickr The only "special" thing I can say about my lighting job is that I don't have to plug anything in, the power to the lights is connected as soon as I drop the body on... |
05-25-2020, 03:27 PM | #12 | |
Wow that is an enormous cut. So I guess the convertible version of this Jeep is a no go? Did you try to put the transmission the other way so the motor pulley is facing forward? Maybe it would be better to fit the interior? If you could also share a photo of your interior, I would be thankful. Sent from my iPhone using Tapatalk | |
05-25-2020, 04:20 PM | #13 |
It looks worse than it is, with the trans the other way around it will come up between the front seats, this way the cut out is more on the backs of the chairs, I致e done it to get the body as low as possible as it痴 quite heavy and would tip over a lot, This is how high the body sits without removing the rock sliders and cutting out anything Sent from my iPhone using Tapatalk |
10-13-2020, 03:46 PM | #14 |
Rock Crawler Join Date: Jan 2014 Location: Granite Falls, WA
I love this thread!! With the days getting shorter, my mind is going back in that direction, of paying attention to the lighting needs of my various rigs. :P Unfortunately, I currently have no lights on my Trailrunner Baja Bug, and my Enduro kit is still in a box. I'm teetering on buying a RTR Trailwalker to mount my Carisma Lynx body on, because I discovered yesterday that the front lines up almost perfect, and only the rear will need modification (wb shortened).
Let's see those light kits! - Similar Threads | ||||
LED light kits | monsterbeetleguy | Traxxas TRX-4 | 8 | 03-28-2020 01:09 AM |
light kits?! | Streamcrawler | General Crawlers | 6 | 11-07-2010 10:41 PM |
Light kits | James003 | Scale Accessories | 8 | 06-15-2010 11:26 PM |
L.E.D. light kits. | Illeagle | Electronics | 8 | 05-13-2009 12:40 PM |
