11-02-2020, 03:55 PM | #1 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
| Kit or rtr
I currently run a heavily modded and capable hpi venture, and also a trx4, am looking at possibly the sendero but not sure wether to get the rtr or the kit. Any suggestions? Clearly your all going to be slightly biased as you already own one 😉 thinking of putting an lc80 on it.
11-02-2020, 04:34 PM | #2 |
Newbie Join Date: Apr 2020 Location: Ukiah California
| Re: Kit or rtr
I am always in favor of the kit. You get to touch each piece and see how it mounts. You get to put whatever electronics, wheels, tire, and body you like on the vehicle. After building, you have a better sense of what's wrong and how to fix it. That is my 2 cents worth. |
11-02-2020, 04:36 PM | #3 | |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: Kit or rtr Quote:
Sent from my LM-G710VM using Tapatalk | |
11-03-2020, 03:52 PM | #4 |
| Re: Kit or rtr
But what does the kit have that the rtr doesn't? I've built enough to not worry about the innards. And I also don't want to end up spending that much more tmon a kit then I would a rtr.
11-03-2020, 04:36 PM | #5 |
Quarry Creeper Join Date: Jul 2019 Location: Torrance, CA
| Re: Kit or rtr I own the kit and from my understanding there is no difference between the RTR and the kit, other than the RTR comes assembled and with electronics.
11-03-2020, 04:44 PM | #6 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: Kit or rtr
The electrics in the RTR aren’t terrible, so if you are looking to get up and running on the cheap and not so much looking to build its a solid option. The kit doesn’t really contain anything special over the RTR. Aluminum shock caps and wheel hexes perhaps? Can’t remember for sure, but no major upgrades. The kit has a great price point. If you like to build, you could go kit and chuck a Hobbywing 1080 and a Holmes brushed sport motor at it to keep the cost comparable. Just use a Tx/Rx you already have. The real deal is on the Trailwalker RTR. They are selling them on the cheap these days. They are the same truck with 1.55 wheels. Personally, my vote goes for kit. Especially if it is your first Enduro. |
11-03-2020, 04:50 PM | #7 |
| Re: Kit or rtr The kit has steel gears in the transmission, links to build multiple wheelbases, and nicer shocks but doesn’t have any bumpers or sliders in addition to the expected no wheels, tires, and body.
11-03-2020, 05:31 PM | #8 | |
Oh and Kit unless you're okay with RTR electronics or you plan to sell them. Last edited by HumboldtEF; 11-03-2020 at 06:49 PM. | |
11-03-2020, 05:45 PM | #9 |
| Re: Kit or rtr
If you have Instagram look up @mikesrch and @fleurdelysrc Lots of scale hard body builds using the Enduro chassis. |
11-03-2020, 09:28 PM | #10 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
| Re: Kit or rtr
I will add my two cents as I have both a kit and a trailwalker. The stock Esc and motor leave a lot to be desired IMO, specifically when compared to a very budget HW1080 and Holmes sport motor. I thought I would run the rtr electronics for a while, but they lasted all of one run. As previously mentioned, the Kit has aluminum shock caps, spring cups, machined steel gears in the trans (5% and 11%, as well as inverse top shaft in case you need to flip the trans) as well as extra links for 11.8”, 12” and 12.3” wheelbases. Kit still has plastic hexes and pivot balls. For that reason, i would strongly consider a gatekeeper kit for my next build, since it includes many worthwhile upgrades. But for me, that would include selling the tube body, trailing arm set up and sway bar to swap it for regular links and shock hoops in the rear. Just something to consider. I easily have $299 into my kit with Ft hexes, pivot balls and a few hard plastic upgrades. |
Kit or rtr - Similar Threads | ||||
Which SCX10 ii? Raw Builders Kit, Cherokee Kit or RTR | Clarkbre | Axial SCX10 II | 30 | 03-27-2020 11:25 AM |
wraith rtr/builder kit , ax10 ridgecrest or scx10 kit hocho/dingo | xC Pirates | Newbie General | 9 | 06-09-2012 06:54 AM |
AX10 RTR or Kit for a build? Kit seems more popular, but RTR has some nice features. | nukexbi | Axial AX-10 Scorpion | 21 | 05-09-2008 01:27 PM |
