04-25-2021, 06:25 AM | #1 |
Pebble Pounder Join Date: Jan 2021 Location: Germantown
| High Clearance Link Question
So.... are the high clearance links supposed to be run long side out? Or long side in? I have seen pictures of them run both ways, and I have tried them both ways and notice no difference in performance. It seems to me that long side towards the center gives more clearance, but no performance difference otherwise. |
04-25-2021, 08:47 AM | #2 |
Quarry Creeper Join Date: Dec 2012 Location: okc
| Re: High Clearance Link Question
This is almost as big of a debate as what is the best crawler tire, lol. I like the flat on the trans side but just run them the way that works best for you
04-25-2021, 12:31 PM | #3 |
Quarry Creeper Join Date: Mar 2016
| Re: High Clearance Link Question This is my element. This is how a installed mine! Sent from my iPhone using Tapatalk |
04-28-2021, 11:41 AM | #4 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
I run them like Jeeptec. Better clearance but your drive shaft will take more of a beating.
04-28-2021, 01:57 PM | #5 | |
| Re: High Clearance Link Question Quote:
These are absolutely designed to have the long end on the skid side. Nothing wrong with trying both though. Simply adjust your pinion angle to point it up a bit more, you can usually get it up and mostly out of the way. Last edited by HumboldtEF; 04-28-2021 at 01:59 PM. | |
04-28-2021, 02:30 PM | #6 | |
04-28-2021, 04:25 PM | #7 |
| Re: High Clearance Link Question |
04-28-2021, 04:52 PM | #8 |
| Re: High Clearance Link Question On a high pinion diff such as an AR44 you can get it better. A portal axle wont' be a problem but with the low pinion on and Enduro axle it will take more hits. I will take the hits. for the added clearance. Yes, the Enduro shaft (CV or ball joint) is a good design but if you are running MIPs (yes I got suckered into buying some) that have a more "U Joint" design they won't do as well.
04-28-2021, 07:43 PM | #9 |
Its possible on the Enduro axles, this is what I ended up with. The pinion is just a whisker above the links. Last edited by HumboldtEF; 04-28-2021 at 07:45 PM. |
04-28-2021, 08:35 PM | #10 |
11-26-2021, 02:28 AM | #11 |
Quarry Creeper Join Date: Aug 2011 Location: United Kingdom
Just came across this post now... I have the BK2 and for reasons known only to Element the kit only comes with the lower bent links (high clearance) but the upper links are still straight! Possibly for cost savings but I can't imagine it would be so much more to add bent uppers! The individually available high clearance link set has both the uppers and lowers bent. What are the known issues and movement restrictions by only having bent lower links? Oh and by essentially clocking the diffs forward to create a shallower pinion angle you are reducing diff housing clearance slightly....i.e. it rotates the underside of the diff closer to the ground. Guess you have to find a happy medium somewhere and can't have everything! Last edited by mr lee; 11-26-2021 at 02:42 AM. |
11-26-2021, 07:28 AM | #12 | |
Rock Crawler Join Date: Mar 2021 Location: Santa Barbara
referring to the original topic... THE BEND GOES AT THE SKID! | |
11-26-2021, 08:21 AM | #13 |
11-26-2021, 08:35 AM | #14 | |
I have bent lowers and straight uppers on the rear of this truck (bend at the skid) ... | |
11-26-2021, 09:09 AM | #15 |
Sorry I assumed most would know what BK2 is...Builders kit 2 Good to know you have not had any problems and many thanks for the feedback! |
High Clearance Link Question - Similar Threads | ||||
help. high clearance link setup | mikedengineer | Axial XR10 | 26 | 03-31-2012 07:42 PM |
lower high clearance link question | eggie | Redcat Crawlers | 4 | 06-11-2010 08:38 PM |
high clearance link direction | solomon7 | Newbie General | 10 | 10-04-2007 10:54 PM |
High clearance link Question for everybody. | rockbender | Tamiya TLT Crawlers | 2 | 02-28-2007 09:32 AM |
