10-05-2021, 11:28 AM | #1 |
Quarry Creeper Join Date: Jun 2018 Location: Blaine
| Knight Runner axle swap.
I need the advise of somebody more knowledgeable than myself. I've found/read on here that the stock gearing on the element trucks is 3.75:1, the RC4WD K44 axle is 2.67:1. Does this mean the K44 will spin slower than the front for the same driveshaft input (2.67 rear axle rotations/one driveshaft rotation vs. 3.75 front axle rotations)? Or am I reading the ratio backwards? I want to install a leaf sprung K44 rear on my new Knight Runner but I want to make sure my tires are spinning close to the same speed. A bit of front overdrive would be okay though. Sent from my LM-V600 using Tapatalk |
10-05-2021, 11:46 AM | #2 |
Rock Crawler Join Date: May 2021 Location: NorCal
| Re: Knight Runner axle swap.
You're reading it right.
10-05-2021, 11:49 AM | #3 |
| Re: Knight Runner axle swap. |
10-05-2021, 12:29 PM | #4 |
Quarry Creeper Join Date: Jun 2009 Location: Winchester
The 2.67:1 axle will spin much faster than the stock 3.75:1 ratio axle. Lower numerical ratio = faster speed.
10-05-2021, 12:53 PM | #5 |
10-05-2021, 02:40 PM | #6 |
RCC Addict Join Date: Sep 2017 Location: The OC
| Re: Knight Runner axle swap. AFAIK Element has overdrive built into/optioned in the transmission/gearbox. Is there a reason to swap an axle out? |
10-05-2021, 05:55 PM | #7 | |
| Re: Knight Runner axle swap. Quote:
I want to swap to a K44 primary for looks and to easily make the rear leaf sprung. If I UD the rear axle in doing so? Not a big deal. I just needed to make sure I was understanding the gear ratios correctly to ensure I wouldn't OD the rear axle. Sent from my LM-V600 using Tapatalk | |
10-05-2021, 06:03 PM | #8 | |
Do you happen to know the element OD ratio off hand (haven't had the chance to dig through the manual yet)? Is it close to the K44 ratio? Edit: I did a bit of digging, what I can get away with at work anyway, and if I'm understanding this correctly, the 2.67:1 K44 would have less torque but a higher speed compared the 3.75:1 stock front end that would have a lower top speed but higher torque. Is that correct? Sent from my LM-V600 using Tapatalk Last edited by smc-93; 10-05-2021 at 06:19 PM. | |
10-05-2021, 06:19 PM | #9 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
Element ratio is 3.75:1 same as standard axial ar44 and ar45 ring and pinion. I’m not super familiar with leaf spring stuff, but I would maybe look into the possibility of using an SSD pro44 rear axle and the jec leaf mounts https://jecracing.com/products/ar-44...29642848895020 https://www.amainhobbies.com/ssd-rc-...zrqaeq6zqxactz One thing you could do if you’re set on using a k44, is reverse the o/d in the trans to the front output (either by flipping the trans, or using the optional top shaft and flipping the gears internally) and if necessary use the 10% gear set to offset the ratio difference. This would also likely require running a smaller pinion to bring the final drive ratio back closer to stock. Curious about the k44 though, it’s built to the same durability as the yota II axles as far as I know, and those are not particularly well regarded in that department. I would assume you’re going for a more scale accurate representation for a 1:1 Tacoma with leaf springs, but in that case, why not use the yota axle? 1:1 Tacoma’s use a rear axle very similar in design and appearance to the original 4x4 Toyota pickups. Last edited by twade984; 10-05-2021 at 06:28 PM. |
10-05-2021, 06:24 PM | #10 | |
I've like the look of the K44 but I've heard mixed reviews on their quality and longevity. Sent from my LM-V600 using Tapatalk | |
10-05-2021, 06:40 PM | #11 |
Just running through the ratios (off the top of my head, so I may be slightly off) Stock spur/pinion: 87/18=4.83 Standard trans gears: 52/20=2.6 11% o/d trans gears: 54/26=2.7 Stock r&p: 30/8= 3.75 K44 r&p: 2.67 Front final drive ratio: 4.83x2.6x3.75=47.09 Rear k44 final drive: 4.83x2.7x2.67=34.81 Total o/d percentage to the front: 30.402% Using the team knk 25% o/d gears for the stealth x (56/20) yields a 25% difference front to rear. Those numbers may be a little confusing because element calls it “overdrive” meaning the front wheels spin faster, but the standard trans gears are 2.6:1 and the “overdrive” gears are actually underdrive gears for the rear output, (2.65=5.5%, and 2.7=11%). Last edited by twade984; 10-05-2021 at 06:45 PM. |
10-05-2021, 06:50 PM | #12 | |
As far as Yota vs. K44? The Yota looks to slender to me. I realize the Yota/Yota2 are modeled after full size Toyota axles but they don't look right to me. The K44 is less scale accurate but I like the beefier look. That being said, I like the look and build quality of the (not scale accurate either) Pro44. Which would also already have the correct R/P ratio to match the front. Sent from my LM-V600 using Tapatalk | |
Knight Runner axle swap. - Similar Threads | ||||
Axle swap? | Synister_Intent | RC4WD Trail Finder 2 | 4 | 02-11-2019 01:58 PM |
Axle swap | dkchance74 | Axial SCX10 II | 10 | 04-21-2017 09:01 PM |
axle swap | dkchance74 | Axial Wraith | 0 | 02-07-2012 12:46 AM |
Axle Swap for CC-01 | dimsum86 | General Crawlers | 6 | 04-11-2007 10:20 AM |
