02-10-2019, 04:01 PM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: Wind Gap
| Axle swap?
Good evening all. Got a quick question for all of you TF2 experts, I'm looking to install a set of Scx10 axles on a TF2 chassis, what would I need to accomplish this? Has anyone done this and able to post pictures as a reference for me? Any and all help will be greatly appreciated. Thank you. Sent from my SM-N920V using Tapatalk |
02-10-2019, 09:46 PM | #2 |
Newbie Join Date: Feb 2019 Location: Cullman
| Re: Axle swap?
Hi. I just happen to have both those trucks and the suspension systems are quite different. Are you planning to retain the TF2's leafs or swap it over to links?
02-10-2019, 10:09 PM | #3 |
| Re: Axle swap? |
02-11-2019, 01:52 PM | #4 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
| Re: Axle swap?
I went with K44 axles for a direct bolt up to the TF2 AND both the FRONT and REAR link kits if that helps you. Those fit right up no problem in both link or leafs.
02-11-2019, 01:58 PM | #5 |
RCC Addict Join Date: Sep 2014 Location: Alberta
| Re: Axle swap?
You could use AR44-based axles (SCX10-II) with JEC Racing's AR44 leaf mounts. I believe they even make some for Vanquish Currie's.
Axle swap? - Similar Threads | ||||
JK Axle swap | Dumptruck | 2.2 Scale Rigs | 22 | 06-17-2009 12:13 PM |
Axle Swap for CC-01 | dimsum86 | General Crawlers | 6 | 04-11-2007 10:20 AM |
1:6 axle swap | Slimpee | General Crawlers | 10 | 10-02-2006 05:54 PM |
