05-24-2022, 01:29 PM | #1 |
Newbie Join Date: May 2020 Location: Belgium
| Front axle facing up driveshaft in wrong angle
After two TRX-4s it was time for something different, time for a Gatekeeper kit. The build is done, but Im not sure about the setup. The front pumpkin is slightly facing up, making the driveshaft facing down. I checked the length of the links and made some slight corrections, but it has no effect on the angle of the axle/pumpkin. What could be wrong with my setup ? According to the manual, the upper link should be 122mm, rod ends included. Should I adjust the length of the link to correct the angle ? |
05-24-2022, 01:46 PM | #2 |
| Re: Front axle facing up driveshaft in wrong angle
Any pics? Are we talking angled up slightly or like a ton? Angling them up a bit isn't a problem and I think all of my Enduro have a bit of this. I've even added a bit more angle on some. Since its not a high pinion like and Axial rig its kind of nice for a bit of extra clearance. EDIT: I missread that, having the driveshaft angled down is not ideal. Personally I would simply adjust the length of the links, shorten the lowers and lengthen the uppers. You can do this by using shorter or longer rod ends or cutting down the stock ones (and typically grinding down the threaded ends to allow the shorter rods to fit). Last edited by HumboldtEF; 05-24-2022 at 01:50 PM. |
05-24-2022, 02:12 PM | #3 | |
| Re: Front axle facing up driveshaft in wrong angle Quote:
I tried taking pictures, but couldn't get the right perspective to clearly show the problem. Ill try adjusting the links tomorrow. | |
05-24-2022, 02:41 PM | #4 |
I wanna be Dave Join Date: Sep 2019 Location: US
Try sightly shortening the lower links and/or lengthening the upper links, until the driveshaft entering the pumpkin (fully compressed AND fully extended) is say the desired angle. ~ More peace, love, laughter, & kindness would make the world a MUCH better place |
05-24-2022, 03:23 PM | #5 |
Pebble Pounder Join Date: Sep 2021 Location: Canada
Might be a stupid question, but do you have the lower links in the top and vice-versa?
05-24-2022, 03:47 PM | #6 |
Rock Crawler Join Date: Jan 2022 Location: st louis
You have the links in wrong. Either mixed up the front and the rear, top and bottom or mounted to the wrong holes in the frame/skid. Sent from my SM-S906U using Tapatalk |
05-24-2022, 06:20 PM | #7 | |
Yeah you could have mixed the links up but you cannot mount the links in the wrong holes and have the driveshaft pointing down, it would point up. | |
05-24-2022, 10:29 PM | #8 |
| Re: Front axle facing up driveshaft in wrong angle |
05-24-2022, 10:39 PM | #9 | |
Ill check it once again. The front lower links should be fine theyre the high clearance that came with the kit. The manual only shows instructions for the straight links. I guess that the length of the links should be the same, regardless of straight or high clearance ? | |
05-24-2022, 10:58 PM | #10 |
The front axle has two mounting points for the upper links. According to the manual, the upper link should be connected to the frame on the drive-side. In connected the upper link to the axle on the mounting side on the passenger-side. Did I mix this one up ? |
05-24-2022, 11:40 PM | #11 |
05-24-2022, 11:59 PM | #12 | |
~ More peace, love, laughter, & kindness would make the world a MUCH better place | |
05-25-2022, 09:44 AM | #13 |
So I changed the connection of the front upper link on the axle, from the passenger-side to the driver-side. As it would be if it was a 4-link setup (and I guess as it should have been). The angle of the pumpkin/axle is now as it should be. Fooled by the manual . Sigh ... |
05-25-2022, 09:56 AM | #14 |
Glad to hear you have it figured out. The manual isn't really clear and if I remember right, it shows straight links instead of the high clearance links that come with the Gatekeeper Kit. Here is a pic of how mine is for a comparison. |
05-25-2022, 10:40 AM | #15 |
Thanks, That's a nice setup ! |
Front axle facing up driveshaft in wrong angle - Similar Threads | ||||
Motor mount facing front option | xv-townboy | Element RC 1/10 Enduro Trail Truck Sendero | 2 | 04-03-2020 04:42 AM |
Front driveshaft pinion angle for Enduro | MechDave7 | Element RC 1/10 Enduro Trail Truck Sendero | 1 | 08-21-2019 03:56 PM |
Losi mrc steering angle options/front axle shafts | xiteamxi | Losi Mini-Rock Crawler | 5 | 04-03-2013 01:33 PM |
trans facing wrong way?? | troy95chevy | Axial SCX-10 | 5 | 08-21-2011 06:33 PM |
BB-51 front driveshaft angle | JasonInAugusta | General Scale Talk | 33 | 03-12-2007 05:52 PM |
