| | #1 |
| RCC Addict Join Date: Aug 2005 Location: VARCOR
| Just reflecting back on running Clod axles, and still seeing some local guys running Clods................I am just not getting anywhere near the amount of stall that Clods seem to have in my experience. Just seems like on a lot of Clods I have run, or seen run, it takes the minimal amount of torque to stall the rear axle, whereas on the Newage, I just don't get much. Sure, given the right situation, the rear will stall (heck, both will given the right scenario), but just no where near as much as with Clods. Maybe it is just my electronics, or the improvements of electronics in general in the past couple of years. Have you noticed a lack of general stall? |
| Sponsored Links | |
| | #2 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| Smaller tires, less vehicle weight, lower effective rollout= more relative force needed for stalling. I have noticed the same thing, there isn't near as much stall on the rear as compared to a clod because the motor is the same power but the vehicle is much lighter. |
| | #3 | |
| I wanna be Dave Join Date: May 2005 Location: CITY of CHAMPIONS!!
| | #4 | |
Just throwing this out there, but I am thinking it is more of a tightness of the drivetrain issue. We all know the gears are tight in the Newage, much tighter than the Clod ever was. I finally got my Newage running with 3 position dig today (rear free), and was amazed by how much drag there was in the driveline even when freewheeling. On a level surface, the rear end wanted to brake/drag even when the motor was free to spin. I am starting to think that "Clod Stall" truly was a Clod thing, and not an axle-mounted motor thing. | |
| | #5 |
| I wanna be Dave Join Date: Jun 2005 Location: With my family
| from what I am seeing, it all comes from gear size. The clods have very large diameter 32p gear. The newage axles have much smaller 48p gears. It takes more power to turn the large clod gears, hence it takes less bind to stall them. |
| | #6 | |
| Quarry Creeper Join Date: May 2007 Location: NCVRCC
| | #7 | |
| RCC Addict Join Date: Nov 2007 Location: Scalers are more fun
| | #8 | |
| Rock Stacker Join Date: Feb 2006 Location: Brisbane, Australia
Part of the reason that we get clod stall is that we run 2 motors off one speed controller. If you ran separate controllers, I think the stall would be negligible. I run 2 different pinions in mine, and have minimized it a little, but it is still there. Brad. | |
| | #9 | |
| | #10 |
| Quarry Creeper Join Date: Sep 2007 Location: Central Coast, NSW, Australia
| Mechanical advantage is mechanical advantage. Its not that important what the gear diameter is as what the total gear ratio is from motor to wheel. The higher the ratio (like 50:1 vs. 30:1), the easier it is for the motor to turn the wheel and the harder it is for the wheel to turn the motor. |
| | #11 | |
Ok now that I have had a look at the Newage stuff, you are trying to compare apples and bananas, they are two entirely different configurations, therefore having different gear reductions. The only thing they have in common are that the motors are on the axle's. Ok, The stock gear ratio on the Newage is 40:1 Stock gear ratio on a clod is 30:1 . The newage ratio is higher, therefore won't stall as easy. Brad. Beat me to it Linc.. No go back and hide in the pit where you belong :-P:-P:-P:-P:-P:-P:-P:-P:-P:-P Last edited by Udlman; 06-02-2008 at 02:58 AM. | |
| | #12 |
| Quarry Creeper Join Date: May 2007 Location: Hilo
| Dont know if clod stall if present on 2.2 clods but the smaller diameter of the 2.2's also affect gearing. |
| | #13 |
| ... Join Date: Sep 2005 Location: USA
| From what I have found out myself is. The Lower geared and more volts you run. The Less Stall you'll get. My 2.2 Clod maybe stalls every 20th time out. Has to just me the perfect spot for it to happen. Never happens on hills. Only in a bind. Which is what I like the most. Its the SLIPPER for CLODS... Kind works like a Shafty in that way. Prevents breaks. But not always. Just last yearin OK. I jammed both right side tires in a V-Noch and snapped to axles at once. No stall... Now on my super. I run the same set up and it does stall more. But The hieght and width of the Moab XL's is the doing there. Some stall is a good thing. Many have said that for years. |
| | #14 |
| TCS Team Manager ![]() Join Date: Feb 2004 Location: on a Big Rock
| | #15 |
| Stock Clod Gear Ratio Pinion 9T 54 : 1 8T 61 : 1 7T 70: 1 6T 81:1 |
| | #16 | |
| RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
who cares about stall ''I want a Berg!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! | |
| | #17 | ||
R2J, Those numbers don't seem right I found these #'s in an old JIA post..... Quote:
| | #18 |
| I wanna be Dave Join Date: Apr 2005 Location: It's good to be a Pirate!
| I welcome a little bit of stall. Keeps you from flopping on your lid when approaching climbs. Nice thing about the Bergs is that they are very well geared so it is not a huge issue. I agree that the smaller wheel diameter and lighter weight rig itself makes a difference as well. I think some other things that play into it is the Sidewinder ESC I am running as well. With its programmability you can send 100% power and the smoother stepping the power is on tap better than ever. I am really enjoying mine but I do miss driving my shafty. |
| | #19 |
| RCC Addict Join Date: May 2006 Location: USA
| i don't have any stall on my clod |
| | #20 |
| Thread Tools | |
| Display Modes | |
