06-06-2008, 05:06 PM | #41 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
06-06-2008, 05:27 PM | #42 |
Rock Crawler Join Date: May 2006 Location: Georgia
What if he flips the motor like Bonus Line did. That way the motor would be in the back.
06-06-2008, 05:40 PM | #43 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
Hey,what about a mount for TCS stick? We need a super with Berg axles |
06-06-2008, 06:47 PM | #44 |
I wanna be Dave Join Date: May 2005 Location: CITY of CHAMPIONS!!
06-06-2008, 07:16 PM | #45 | |
I just measured them for you. All measurements taken from king pin screw to mounting face on the gear case. Short side = 2.11in Long side = 4.07in Difference of 1.96in So you are looking at 2in narrower on the axle. Currently with my narrowed hexes I'm at 8.5 wide measuring from the outside of the hex. So in short if you use 2 narrow axle tubes you would have a 6.5in wide axle. | |
06-07-2008, 12:36 PM | #46 |
Rock Crawler Join Date: Mar 2008 Location: Arizona
The FedEx man just droped off my Berg/Newage. It is evenmore impressive in person. Kind of makes my AX-10 look like a piece of crap. Even the hardware is impressive. I can not wsit to get it going |
06-07-2008, 06:10 PM | #47 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
06-07-2008, 06:49 PM | #48 | |
The Wheels Keep Turning Join Date: Jan 2004 Location: Phoenix, Arizona
06-08-2008, 09:13 AM | #49 |
RCC Addict Join Date: Nov 2007 Location: E.T.R.C.
Anyone tried the pro-line wheels yet???
06-08-2008, 02:18 PM | #50 |
Quarry Creeper Join Date: May 2007 Location: Hilo
I got 1 question, just ordered 1 and was wondering what I should look at as far as breakage?? Should I stock up on anything? you know the usual questions. Thanks mike |
06-08-2008, 02:33 PM | #51 | |
RCC Addict Join Date: Aug 2005 Location: VARCOR
I have read of a couple of inner axles getting twisted. But the one component I have read the most about is the outer axle stubs shearing. Good thing about outers though, is that AX-10 stubs are a direct replacement, and have held up better. This is based on what I have read though, not personal experience. | |
06-08-2008, 06:08 PM | #52 | |
The truck in general seams pretty durable though. Last edited by kevinlongisland; 06-09-2008 at 08:56 AM. | |
06-09-2008, 08:53 AM | #53 |
Great!!! Glad someone found that the axials work better. I may have to get a set just in case!
06-10-2008, 05:25 AM | #54 |
Pebble Pounder Join Date: Jul 2005 Location: Wailuku
Looking to get this rig soon. Does anyone know if the Vanquish beadlocks fit on the axles? Any clearance issues? Pics? Thanks in advance.
06-11-2008, 07:36 PM | #55 |
Quarry Creeper Join Date: Feb 2008 Location: no more lockers
wow nice room , the kegerator is over there > nice to have our own forum thank you |
06-11-2008, 07:41 PM | #56 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
Yep, It is kinda nice!
06-11-2008, 08:01 PM | #57 |
varcor.org Join Date: Aug 2005 Location: 757
sweet... no more digging thru the forums for ideas...
06-12-2008, 07:42 PM | #58 | |
It has always been known that these wheels, although attractive in stock form, were never really meant for the width of the stock axles. Newage could have done a MUCH better job with the offset. With the offset issue pushed to the side, I have always stated that these wheels would be great for other projects, i.e. projects with narrower axles. The only other complaint I have had about the wheels is the size of the hardware. The ring mounted screws are simply tiny and weak.............in fact, I broke a couple of heads off just installing the rings. It is a fine line between getting the screws tight enough to properly grab the tire, and shearing the heads off. After running the stock wheels for a few months, the tiny hardware issue came to light when I went to remove the rings. The hex "pocket" was small to begin with, but once you add in a couple of months of rock scraping them, it is damn near impossible to "grab" the hex pockets at all. There was just nothing left of the head to catch. Between all four wheels, I ended up grinding the heads off of about nine screws so that they could be removed. The hardware on the stock wheels is just too small for real crawlers!!!! So, looking back at my statement above, if you remove the value of the wheels, and yes, I LOVE the stock shocks, but others are available pretty cheaply......................once you add in these factors, the kit may not be the better deal over the axles that I once believed. Right now, I put the value cost of the kit vs. the axles alone at about equal.................with me on the fence either way right now.:-P | |
06-12-2008, 08:03 PM | #59 |
I never really considered getting the kit because of the wheels, when I knew I would never use them due to the offset. But that's good to know about the wheel hardware for those who might put them to use. The only bonus I could see for getting a kit over just the axles is the servo mounts, which do not come with the axles. But for almost $100 more I couldn't justify buying the kit. I will just have to get a little creative with my servo mount. |
