| | #1 |
| Rock Crawler Join Date: May 2006 Location: Georgia
| After owning this truck for close to 3 weeks and seeing all of the OCM/Berg threads I guess I need to post mine. Specs: Integy 55t Mamba Maxx 3cell 1500mah Li-Po Hobbico CS-170 for steering HS-81 + micro switch for Dig CAC Tucker wheels Nomadio react Nothing special reallly. I used the Links included for the rear bumper for rear uppers. This clocked the rear motor up for clearance. I also limited the shocks inside and out to limit articulation. I have 3 3/8 under the skid. ![]() ![]() This was with my F-350 body slammed. ![]() ![]() I cut the F-350 to short so I needed a new comp legal body. I decided to give the C-10 a shot. It works pretty well. ![]() So far the truck works great. I placed 3rd at the SERCRC comp on Saturday behind Kamikazes ZERO driven by joebruiser in 2nd and RXcrawler in 1st. Only problems so far have been the Stub axles. I bent all 4 in its first outing so I replaced them with AX-10 stubs and they seem to hold up fine. Last edited by TLTRyan; 06-03-2008 at 10:10 PM. |
| Sponsored Links | |
| | #2 |
| Moderator ![]() Join Date: Apr 2004 Location: In my head
| Truck looks good Ryan, and you know I love the wheels. Have you had any problems with the axle shafts wanting to slide out of the diff after swaping the stubs? |
| | #3 |
| DIRTY SOUTH ![]() Join Date: Sep 2005 Location: Dirty South
| | #4 |
| Thanks Joey. I did just what Badd said, I reused the 0-rings out of the stock stubs. |
| | #5 |
| Quarry Creeper Join Date: Dec 2006 Location: Acworth
| It drives like a Caddy. Very smooth and predictable. Wish I knew how you get it to bunny hop though. |
| | #6 | |
| I wanna be Dave Join Date: May 2005 Location: CITY of CHAMPIONS!!
| dude, you had to have lost a ton of turning radius with the way you clocked your front axle tear that thing apart and clock it correctly you can prob get at least 1/3rd more turning radius. other than that nice looking rig!! Quote:
thanks | |
| | #7 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| Only his rear axle is clocked. Looks good! That stock chassis is tiny. |
| | #8 |
| I wanna be Dave ![]() Join Date: Oct 2005 Location: Columbia TN
| | #9 | |
| | #10 |
| | #11 |
| ok, that kinda clears it up. i haven't torn apart the axles yet, i am guessing that there are no retainers on the inner axles shafts then? thanks! |
| | #12 | |
oh by the way Ryan I really like the Tuckers | |
| | #13 |
| yeah, i saw that on your post, but i couldn't really tell from the pics if there were any retainers. the tuckers are nice, i am running the sinners and a guy in my club has the tuckers. width wise our 2 trucks are almost identical believe it or not. his with the tuckers are only about 1/16 to an 1/8 at the most wider on each side. overall 1/8 to a 1/4. tltryan, i like the c-10 body i looks great! |
| | #14 | ||||
| | #15 |
| Quarry Creeper Join Date: Aug 2007 Location: Go Broncos!!!!!!
| Lookin' good Ryan. |
| | #16 |
| Rock Crawler Join Date: Mar 2008 Location: Arizona
| Any modifications to teh stock shocks? Mine leak just standing still. |
| | #17 |
| | #18 |
| Quarry Creeper Join Date: Feb 2008 Location: no more lockers
| my shocks leaked horribly , the factory forgot to put o-rings in mine . i put 2 of the silicone o-rings from the kit in each shock and no more leaks . i think some shocks have them and other kits dont so check your shocks before filling . |
| | #19 | |
Mine also. Berg Newage Shock Fix that is what I used to fix them. Could have also used the stock orings in the kit but I had the rebuild kit in my box already and it fit just right. | |
| | #20 |
| My 8 month old Losi's where showing some wear so I decided to try out some Panthers. The compound is really soft so I decided against the memory foams they come with. I went with Axial foams in the front and Pro-Line foams in the rear and I narrowed the foams to the width of the wheels. I really like the extra height and they seem to perform as good if not a little better than the Losi's. |
| Thread Tools | |
| Display Modes | |
