Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > EnRoute Berg
Thread: Bonus line's berg
Old 06-05-2008, 11:27 AM   #1
Default Bonus line's berg
thought i would share my berg build with everyone , hopefully i can come up with some good ideas for this build and learn a lil something too.
i am going for an ultra low cog, simple design and function.
ok some observations of the berg kit.
first things first i hope berg is watching , the rod ends are terrible , now that's out of the way the rest of the kit has nice part .
i wont be using most of it lol
clocking the axles was the first goal and last night i completed the rear axle flip flop and clock to move the motor above and behind the rear axle for more clearance .
today i will start on the front axle clock and custom battery servo mounts.
specs for this build
berg axles
axiom 45t hand wound x2
CAC tucker wheels flippin bad ass
panther tires
mamba max
electro disco
spektrum dx3r
chassis and shocks tba
after doing the rear axle last night i decided to throw the kit together to see what the stock configuration was like.
i notice a good amount of axle steer so not an ideal link geometry from the stock kit . that will be addressed with a new chassis . i also feel the shocks are laid down to far and are not effective with the 30 wt oil the kit recomends .
maybe 90-100wt shock oil would help but again new chassis will solve this issue too.
you can find more info on the rear axle flip flop here
berg/ocm rear axle flip and clock
here are some shots of the stock kit and rear axle flip
BoNuS LiNe is offline   Reply With Quote
Old 06-05-2008, 11:49 AM   #2
OCCUPY RCC!
dezfan's Avatar
Very clean, do you have enough wheel speed w/ that motor?
dezfan is offline   Reply With Quote
Old 06-05-2008, 12:41 PM   #3
Its making up for not having one in the front
these things are the Clod of 2.2s
what motor combo are you going to be running?
Jeepernick is offline   Reply With Quote
Old 06-05-2008, 01:23 PM   #4
Axial Team Driver
Brandon's Avatar
Nice Alan! Sending a PM your way
Brandon is offline   Reply With Quote
Old 06-05-2008, 01:36 PM   #5
OCCUPY RCC!
dezfan's Avatar
35T's on 3C lipo.
Old 06-05-2008, 03:56 PM   #6
Kamikaze's Avatar
I hope that motor is a joke.....
Kamikaze is offline   Reply With Quote
Old 06-05-2008, 04:37 PM   #7
4c lipo with 2x 7700kv mambas lol jk that's a motor out of my b44 just in there for mock up . waiting on some axioms 45t's
axiom hand wound 45t
got it
35T's on 3C lipo.
close
april fools lol rock racer motor man
Old 06-05-2008, 05:42 PM   #8
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
Nice so far I like the clocked rear axle will the front axle get some clocking?
Stormin2u is offline   Reply With Quote
Old 06-05-2008, 05:47 PM   #9
yes i am working on the front axle today along with a new servo battery mount . also this build for the wcc will be running the top banana chassis thanks! jake aka del monte go banana
Old 06-05-2008, 05:55 PM   #10
Gold Star Baby!
Stormin2u's Avatar
Gonna be awesome Bonus
Old 06-06-2008, 01:13 AM   #11
front axle clock finished , i followed robb's write up to get me started this is also a really simple mod that should be done to prep the berg for comp .
i clocked it slightly further than robb did in his write up so that i could then rotate the motor back down a little to gain some negative castor . the stock rig sits at 0 degrees i tilted it back for better steering and it helps with sidehill bite when trying to steer up hill from sidehilling . another perk to over clocking and then turning back to gain castor is that it moves the tie rod to a higher position .
while i was at it i bent the lower links for high clearance
also playing around with different bodies i found the hpi bug body fit perfectly over the tiny berg chassis and can sit lower than the grappler or the new c10 .
the car can nearly be driven upside down with the bug body so my choice for comp body is simple .
next up will be the servo battery axle mount
cheers
Old 06-08-2008, 02:11 AM   #12
Originally Posted by GH Racing View Post
looks nice
thank you
came up with this idea for an axle mount platform using the bumper plates , simple super sturdy mount that can be clocked. perfect for a lipo or ?
using both bumper mounts is not needed , this mod is burly for what ever you mount .
not sure if i am going to use it for anything but i thought i would share the idea anyway .
Old 06-08-2008, 03:05 AM   #13
I used my stock bumper on the rear axle as a battery mount and have since decided to move away from that arrangement because it eats up ground clearance. I really did notice the difference. I think if it would be less bad if the bottom was a smoother transition like the servo mount. Give it a try anyways, it may not bother you.
chrisjlittle is offline   Reply With Quote
Old 06-08-2008, 08:24 PM   #14
finished up the rear axle lock out .
seeing how everyone has done theirs i tried to keep it simple and tough . i like some of the other ways people have done but i feel this the best way for my build.
i did not want to use threaded rod ends for the lock out strut because the possibility of pulling out a thread , been there done that . i like kamikazi's mod but i wanted a little bit of triangulation . i just feel triangulation is always stronger .
this way also tucks everything nicely into the wheel .
first flip your knuckles so the steering horn faces toward the front , this allows the strut to go inside the wheel because of the offset mounting hole on the axle.
the next thing i did was eye up where on the strut the hole needed to be then i drilled one strut . bolt the other strut to the one drilled and then use the first hole as your pilot to make them equal length .
in order to align everything for drilling into the knuckles everything was locked parallel and then drilled to keep side to side toe in equal .
turned out well
should have the servo/battery mount doe tonight so more updates to come.
Old 06-08-2008, 08:43 PM   #15
Nice job on the rear lockout.
TLTRyan is offline   Reply With Quote
Old 06-08-2008, 10:54 PM   #16
Dream...Think...Create.
Nova's Ark's Avatar
Wow, nice build.
Nova's Ark is offline   Reply With Quote
Old 06-09-2008, 09:58 AM   #17
thanks ryan , just trying to keep it simple.
Originally Posted by Nova's Ark View Post
Wow, nice build.
thanks for kind words
now if the rest of the parts im waiting on show up i'll be golden
Old 06-09-2008, 10:08 AM   #18
on your lockout, did you flip the knuckles? i am guessing thats how you lined the lockout up parallel to the top of the knuckle. was there any prob doing this? are the knuckles reversible with no difficulties? thanks
rockbound is offline   Reply With Quote
Old 06-09-2008, 11:09 AM   #19
in my quick write up a couple posts up i wrote that i did flip my knuckles , flipping the knuckles was the only way i could get the lock out strut inside the wheel because of the offset of the axle mount .
the knuckles can be flipped no problems
Old 06-09-2008, 01:57 PM   #20
Location: at the bench of the up 'n coming '79 ford crew cab
Bonus this will be a great comp truck. i really am stoked to see your finished product. nice builds always come out of your shop man! lookin killer!
clod & bruiser is offline   Reply With Quote
