Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > EnRoute Berg
Thread: Berg + Zero + Berg Shocks .. what oil ?
Old 07-01-2008, 02:22 PM   #1
Default Berg + Zero + Berg Shocks .. what oil ?
Any advises on what oil weight to use on a berg with the zero chassis and the berg shocks ? (standard rig, tires, etc, just zero chassis instead of stock)
NullMind is offline   Reply With Quote
Old 07-01-2008, 02:59 PM   #2
Kamikaze's Avatar
I wouldn't recomend running the berg shocks at all. 90mm shocks is what it was designed for, but they will work. I can't promise good results though. The stock oil should be fine.
Kamikaze is offline   Reply With Quote
Old 07-01-2008, 03:56 PM   #3
good to know, what are some 90mm shocks ? can you give me some examples (are the losi crawler shocks 90mm ?)
Old 07-01-2008, 04:14 PM   #4
OCCUPY RCC!
dezfan's Avatar
I recommend these from JP CUSTOM RCs.
http://www.jpcustomrcs.atomicshops.c...79/4462031.htm
I'm running them on my Zero.
dezfan is offline   Reply With Quote
Old 07-01-2008, 04:18 PM   #5
Yeah, saw them, looks good, was wondering if other companies like HPI, Losi, Hobao, etc do some, so I can get them here in the UK
Old 07-01-2008, 05:09 PM   #6
Kamikaze's Avatar
I use these. http://www.jpcustomrcs.atomicshops.c...79/4462031.htm
Old 07-01-2008, 05:50 PM   #7
crawlinghulls's Avatar
I use the slightly longer version of this shock in a droop front end with excellent results.
http://www3.towerhobbies.com/cgi-bin...&I=LXM700&P=SM
crawlinghulls is offline   Reply With Quote
Old 07-03-2008, 08:04 AM   #8
ok, I got some 90mm loi shocks with loi white springs
what shock oil do you guys recommend with this setup then ?
Old 07-03-2008, 02:01 PM   #9
Kamikaze's Avatar
15 wt.
Old 07-03-2008, 02:17 PM   #10
Mic
I run the stock shocks full droop, internal springs and 3/4" fuel line stoper out side for ride hight. 35wt front 70/35 (about 1-2mix rear)
***---Stars and Bars---***
Mic is offline   Reply With Quote
Old 07-05-2008, 06:41 AM   #11
15 wt.
wow, thats thin .. thanks, I will try it
