09-02-2008, 06:03 PM | #21 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
09-02-2008, 06:11 PM | #22 | |
She not that fat, it weights in at 6lb. 14oz. Last edited by ROCKEDUP RICKY; 09-02-2008 at 06:15 PM. | |
09-13-2008, 03:37 PM | #23 |
My berg is so much fun to drive. :-P |
10-05-2008, 07:14 PM | #24 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
What's your ground clearance under the chassis?
10-07-2008, 07:18 PM | #25 |
| It's 2 -1/2 . at ride height. 3 -1/2 extended.
10-14-2008, 07:37 PM | #26 |
The rig worked great at CRAWLAPALOOZA, took home the 5th spot. |
10-14-2008, 07:49 PM | #27 |
RCC Addict Join Date: Jun 2004 Location: Little Rock, AR
10-14-2008, 08:16 PM | #28 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
10-14-2008, 08:59 PM | #29 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
10-15-2008, 12:35 PM | #30 |
10-15-2008, 03:14 PM | #31 |
Newbie Join Date: Dec 2006 Location: USA
Rockedup ricky hate to sound dumb here but what are clocked up axles you mention in the first post? came down to the crawlapalooza last weekend and after seeing the 2.2 rigs run sure makes are scratch built from a couple of years ago go seem way outdated. any suggestions on building a 2.2 class rig shaft versus no shaft. thanks mike |
10-15-2008, 05:04 PM | #32 | |
Clocked axle is rotating the axle so the motor on a shaftless axle is higher or on a shafty the drive line . As far as shafty versus no shafty. I'm still tossed between the two. | |
10-16-2008, 04:27 PM | #33 |
Ricky thanks for the reply. so i assume that you have both rigs shaft and no shaft. i would think the electric dig versus the mechanical dig would be a little less prone to mechanical problems. also from what we saw down there that dig is a must have on a comp rig yes or no? is there any thing else that you can think of? thanks mike |
10-16-2008, 07:24 PM | #34 | |
11-09-2008, 07:47 AM | #35 |
I had a little blow out with my panthers |
11-09-2008, 07:58 AM | #36 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
I think blow out is a understatement:-P Nice work Good to see ya getting some use out of those Panthers. Later Farmer |
02-27-2009, 09:23 AM | #37 |
Rock Crawler Join Date: Mar 2006 Location: Holiday, FL
Is the chassis the same with as stock if you where running a R-2 tranny in it as a shafty?
02-27-2009, 09:49 AM | #38 |
This chassis is suppost to bolt to the R2D, I made a skid plate for it and my width was 2.25 outside to outside of chassis.
