09-30-2008, 07:46 PM | #1 |
Pebble Pounder Join Date: Jul 2008 Location: Trumbull, CT
| jombo's plane bta
since i am a plane guy i thought this may work,i grabbed a pair of bellcranks off my plane and put them on the end of the c hub. will this work i dont know yet, i have been playing with the idea for 5 hours so it looks like it may work and the servo will be facing back behind the axle. more to come.... i hope soon |
09-30-2008, 08:15 PM | #2 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Those will last forever!! As long as you don't hook a servo up to it.
09-30-2008, 10:55 PM | #3 |
Rock Crawler Join Date: Aug 2007 Location: mesa az
i didn't want to be the first to say it
09-30-2008, 11:22 PM | #4 |
Quarry Creeper Join Date: Nov 2007 Location: san diego
WOW, what more can one say
09-30-2008, 11:40 PM | #5 |
Newbie Join Date: Aug 2005 Location: SF
Awesome idea. You have PM.
09-30-2008, 11:43 PM | #6 |
RCC Addict Join Date: Jun 2008 Location: Wasilla
10-01-2008, 06:58 AM | #7 |
thanks for the encoragemet there its not the final product its just there temporarily till i get final measurements to make some parts . like i said i dont know if it will work but they use it for nitro all the time and saw an oportunity to use it here. if you look at all the truggys they all have some sort of bell crank connecting them to the steering tires. but all your oppinions are welcome |
10-01-2008, 03:29 PM | #8 |
I wanna be Dave Join Date: May 2005 Location: CITY of CHAMPIONS!!
the ideas is good, the plastic is BAD! you need to make some parts out of aluminum or metal after you figure out what all you need. the plastic isn't going to hold up. |
10-01-2008, 06:27 PM | #9 |
Pebble Pounder Join Date: Apr 2008 Location: Fort Wayne
Keep working on it dude. A buddy of mine had this idea, but he never went anywhere with it. See if you can get it working. Ben |
10-01-2008, 09:00 PM | #10 |
i see, yes i dont know if they make a aluminum set, i may need to go with some aluminum controll horns, these that i am using now came out of a .60 sport thunder tiger low wing. the berg is back in its box for now i need to finish some remodeling in the house or i will be crawling
10-06-2008, 06:06 PM | #11 |
i think this will work, after trying the 45 degree bell cranks i came up with these. i made them out of some 3/8 or 1.4 inch round steel stock and dont know the angle but i believe its close to 30 or 35 degree bend. i still need to clean it up so there arent any jagged edges but it will miss the tires. the drag link goes up top and i believe i can get the servo to face the rear .... now on to the pics |
10-06-2008, 08:15 PM | #12 |
umm... its no longer behind the axle.
10-07-2008, 10:06 AM | #13 |
| the only thing behind the axle are the steering arms, this was never to put the linkages behind the axle there is no way. all that could be done was raise the drag link above the motor line near the upper links and put the servo facing behind the axle . this way you will hit the tranny before you hit the drag link, waaaay before |
10-07-2008, 11:56 AM | #14 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
Is that a coat hanger?
10-07-2008, 12:52 PM | #15 |
| i think its 1/4 inch or 3/8 steel rod Edit: 3/16 round stock Last edited by jombo; 10-07-2008 at 01:26 PM. Reason: the actual size |
10-07-2008, 05:45 PM | #16 | |
10-07-2008, 06:21 PM | #17 |
i couldnt get the servo to fit on the axle if i kept it that way. i had a problem getting the servo mount on with the servo. the way its now i have the drag link just under the servo plate and the servo arm above it and still clears the shocks (which i forgot about) Last edited by jombo; 10-07-2008 at 06:42 PM. Reason: added pics |
10-07-2008, 06:37 PM | #18 | |
Quarry Creeper Join Date: May 2008 Location: ncrccrawlers.com
| Quote: | |
10-07-2008, 08:11 PM | #19 |
good thinking, so after some tweeking and some moving around some things i got the servo facing back again and it misses the shock . now i need to fix the tires they are falling off the rims since i only have 2 screws holding them in. |
10-12-2008, 03:20 PM | #20 |
Quarry Creeper Join Date: Jan 2008 Location: Cumming/ North ATL
it will never work. . . . .that is all |
