Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Rockcrawlers Berg/enroute Build.......Finally.
Old 12-31-2010, 06:36 PM   #661
So is this still Jeff's or did you take it over?
redbaron is offline   Reply With Quote
Old 12-31-2010, 06:44 PM   #662
I have taken it on for now. Gonna be a spare/back-up/loaner for Jeff and I and others. I'll probably wind up getting a 4PL for it to use as a rig for the new guys that show up to comps and GTGs who wanna try a crawler.
In the end it's just a rainy day killer project, like today
TEDROCKZ is offline   Reply With Quote
Old 12-31-2010, 07:06 PM   #663
As it sits, I had thrown some spare elects in it to play around with. along with some wheels/tires I had mounted up.
Some of the new parts. Rest should be here probably Monday. 66 tubes is gonna be ready soon.
My first attempt at cleaning up berg cases...y'all don't laugh. Not to shabby though using a belt sander and faom sanding blocks
Old 12-31-2010, 07:17 PM   #664
I'll send you my case's cause those look great!
Speedracer19 is offline   Reply With Quote
Old 12-31-2010, 07:39 PM   #665
It's not that bad Donnie. I just clamped the belt sander in a vice, locked down the trigger and let fly. I used a dremel in the tight spots, just gotta go slow with it though as it tends to wanna melt the cheap Al a little. A fine foam sander block will shine it up some.
I may slick them up some more and send them to my new anodizing guy to black them out...
Old 12-31-2010, 08:18 PM   #666
Those cases look good Steve!!! I didn't take the front of my cases all the way down. You can still see where the bolt was. But after seeing yours, I may take mine back apart!!
Old 12-31-2010, 08:46 PM   #667
There is about .045" left in the case where the screw was.
Old 12-31-2010, 08:53 PM   #668
Ok, thats it!! You talked me into it!!!!!
Old 01-01-2011, 02:23 AM   #669
Nice Steve! I do still miss that rig.
Rockcrawler is offline   Reply With Quote
Old 01-01-2011, 04:16 PM   #670
Shiny!!! I got a little off on a hole or two. But these were all extra gears
Guess I need to start my own thread and stop jacking this one.
