11-29-2008, 06:25 PM | #1 |
| *Prototype TK Twister Berg Build*
One of my fellow club members is set to release the new TK Twister chassis set and I am lucky enough to get one of the prototypes to setup with berg axles. More information can be found here: TK-Twister chassis coming soon A build by The Real Dogman with this chassis and Axial gear can be seen here: The Real Dogman's TK Twister '08-'09 Winter Point Series Comp Rig My equipment will include: TK Twister Chassis Bergs (with Axial stub shafts) Jato shocks (yellow springs, 30w oil, #14 pistons in front and #13 pistons in the back) 1/4" aluminum links with Revo ends Berg offset Eritex Comp Heavies Panther Cougars Beat Losi Grappler DX3 35 turn V11s Mamba Max CC BEC Thunder Power 2070 mAh 3s 25c lipo hs 645mg (to be replaced with a jr 8711) hs 81 with radio shack dig switches So far I have rebuilt the Jatos (they are so much smoother now) and built the rear links. This chassis is setting up very well with the berg axles. The link seperation at the chassis compliments the bergs. I clocked the rear axle with link length. |
11-29-2008, 06:26 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Looking good. |
11-29-2008, 07:27 PM | #3 |
RCC Addict Join Date: Dec 2005 Location: Tucson
| Have fun with that chassis, short shock suck for the berg Last edited by Flyin Hawaiian; 11-29-2008 at 07:29 PM. |
11-29-2008, 07:58 PM | #4 |
Quarry Creeper Join Date: Sep 2008 Location: sterling VA
nice looking chassis, let us know how it performs, i like the design.
11-29-2008, 08:24 PM | #5 |
Still saving up for that second axle huh Good looking chassis, I still have never tried the short shock trend. |
11-29-2008, 08:29 PM | #6 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
11-29-2008, 08:50 PM | #7 |
It took Sam one time to drive my Berg Zero and he was hooked. finally Sammy is ready for a podium spot.
11-29-2008, 08:53 PM | #8 |
RCC Addict Join Date: Mar 2006 Location: Xxx
11-29-2008, 08:56 PM | #9 |
11-29-2008, 09:07 PM | #10 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
Looks good! Nice and low.
11-29-2008, 09:19 PM | #11 |
The only problem I have seen from those shocks is the valving is way to slow. Drill some holes in the thingymabobs and you should be golden.
11-29-2008, 09:25 PM | #12 |
11-29-2008, 09:28 PM | #13 |
Quarry Creeper Join Date: Jul 2008 Location: Newark
Good looking chassis...I too run revo shocks 3" is all you need and maximize the linkage setup to full articulation the short shock travel will limit the articulation...works good for me, and I used the #1 piston which is the bigger hole...and 20wt. with jato soft springs |
11-30-2008, 07:24 PM | #14 |
I drilled and tapped the tubes on the front axle tonight. Blue Loctite on every screw in the axle. Lucas "red and tacky" on the gears. This picture shows how much I clocked the axle. |
11-30-2008, 09:34 PM | #15 |
I ordered an Airtronics 94780M tonight from CKRC. 423 oz-in of torque while still maintaining a .15 sec transit speed It should be able to throw around the Cougars...
11-30-2008, 09:46 PM | #16 |
You dont have to clock the front axle it raises the COG im thinking of clocking mine back to stock.
12-01-2008, 11:44 AM | #17 |
Quarry Creeper Join Date: Dec 2005 Location: Albuquerque
| when you get that "clocked" axles on the truck would you please post another pic. just for reference
12-01-2008, 06:34 PM | #18 |
Rock Crawler Join Date: Aug 2007 Location: Tucson
Sam I like the way your build is going. This would have been a venture I wanted to take at a future time. You beat me to it. Chassis should be ready very soon. Great job so far
12-01-2008, 08:39 PM | #19 | |
I shaved the stock berg hexes to work with my Eritex wheels: Drilled and tapped the arms: Then trimmed them: | |
12-01-2008, 08:59 PM | #20 |
Quarry Creeper Join Date: Dec 2006 Location: dot com
Looks real good Sam. I still have to do that to my knuckles. If I was going to clock axles again I would do it that way too instead of drilling the cases.
