06-21-2009, 03:23 PM | #1 |
Newbie Join Date: May 2009 Location: On the rocks
| My KK 4.0
I got my berg built after tracking down all the bolts I needed. Everything seemed great but it's extemely bouncy and wants to flip over backwards on everything. Heres the specs KK 4.0 with High clearance rear Medium front links Losi 4" shocks with white springs front and rear Vanquish pro comps with HB Rovers (proline dual stage oversized foams) Dual FXR's with 45T Tekin HW front clocked 20* Rear clocked with the Traxxas 112mm uppers CKRC BTA steering until the CDW is ready to go JR 8711 servo Futaba 4pk Just need some help figuring out the bounce and flipping over backwards |
06-21-2009, 03:30 PM | #2 | |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
Did you vent your wheels or tires? Last edited by treday619; 06-21-2009 at 03:33 PM. | |
06-21-2009, 04:00 PM | #3 |
Yes they are all vented and i'm running 50wt shock oil
06-22-2009, 11:01 AM | #4 |
Quarry Creeper Join Date: Jun 2008 Location: Portsmouth UK
I had the 2 stage foams and changed them to drilled panthers coz i got too much bounce.The 2 stage were ok in my SWX as it was heavier. You could try a bigger pinion in the front to stop it flipping. |
06-22-2009, 02:10 PM | #5 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
06-22-2009, 02:22 PM | #6 |
I wanna be Dave Join Date: Dec 2008 Location: ?
I have the same rig I run Traxxas big bore with 30 weight and losi white spring look at Joe B. Rig it is dialed. MOunt your links like his (that the easy route look at the best) Also I run a 4pk as well when you are going up hill just roll the wheel by your thumb to about 50% power in the back you will then just be pull the back up with just a little help from the rear. It works alot better than free wheel real. |
06-22-2009, 03:18 PM | #7 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
06-22-2009, 09:11 PM | #8 |
Well right now I have the front wheels full of the slugs and wrapped with 4 ounces of weights each. No weight in the rear right now. I have the steering tore apart trying something different but i'll post some pics anyways.
06-22-2009, 09:26 PM | #9 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
How high is it sitting?
06-22-2009, 09:30 PM | #10 |
06-22-2009, 10:18 PM | #11 |
| 3.25" I had it limited to 3" but I got hung up a lot. Also i'm running a 12 tooth rear and 13 front for pinions Last edited by Ram Tuff; 06-22-2009 at 10:23 PM. |
06-22-2009, 10:20 PM | #12 |
| Sorry the pics are kinda dark. |
06-22-2009, 10:25 PM | #13 |
Ah, the rear upper links are to low, move them as high as you can. Move the front ones down lower.
06-22-2009, 10:33 PM | #14 |
Rock Crawler Join Date: May 2009 Location: just north of BFE in SC
Yea sounds like its too high. . . what is your width and your length? |
06-22-2009, 10:39 PM | #15 |
06-22-2009, 10:41 PM | #16 |
| Thanks a lot. Changed it. The other problem is I can't find lock outs and so far the stock berg lockouts have claimed one rover and on panther. I don't want to run the truck anymore. Tires are going to get expensive!
06-22-2009, 10:42 PM | #17 |
We better just stick with overall height |
08-01-2009, 06:49 PM | #18 |
Rock Stacker Join Date: Apr 2009 Location: st.george
I have that same truck i think it is foams you need to work with.
08-01-2009, 07:59 PM | #19 | |
Pebble Pounder Join Date: Aug 2008 Location: Cary, NC
WOW Super Duty Low profile BERG Lockouts ! | |
08-02-2009, 02:28 PM | #20 |
Rock Crawler Join Date: Jul 2007 Location: central PA
I would try laying the shocks down also. Seems to help keep my truck planted better.
