View Poll Results: How do you like your Berg? | |||
Light as possible. | 22 | 48.89% | |
Heavy. | 23 | 51.11% | |
Voters: 45. You may not vote on this poll |
07-31-2009, 12:38 PM | #1 |
Rock Crawler Join Date: Jan 2006 Location: Southwestern Pa.
| Light or heavy? What is your setup?
I just weighed my rig and with Battery it is right at 8.0lb. Just curious what other Bergs are, and what everyone prefers on a Berg, light or heavy?
07-31-2009, 01:04 PM | #2 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Heading toward "Light as possible" and I figure if I don't like it at least I can choose exactly where the weight goes back on.
07-31-2009, 01:11 PM | #3 |
Rock Crawler Join Date: Nov 2008 Location: kansas city
as long as the weight is low... i dont mind
07-31-2009, 01:15 PM | #4 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
dang man. Mine is right at 6lbs 9oz. I thought it was kind heavy but 8lbs make mine pretty lite huh? |
07-31-2009, 01:25 PM | #5 |
Rock Crawler Join Date: Jul 2007 Location: central PA
Right around 6 lbs with a suspension thats very soft and flexy and a good forward weight bias
07-31-2009, 01:55 PM | #6 |
Quarry Creeper Join Date: Aug 2008 Location: Grand Jct.
mine is at 7lbs flat without body with body its 7.188 lbs |
07-31-2009, 01:59 PM | #7 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
I just got down to 5lbs with a 500 3c.
07-31-2009, 02:06 PM | #8 |
Rock Stacker Join Date: Apr 2008 Location: Norcal
Mine ia just over 6 lbs with 16 gauge wire and delirin wheels. But I only have four ounces in the front and think it could use a little more weight there. I might try swapping the rears to a lighter wheel though before I add more. Wow thats light, what motors are you running with that battery? |
07-31-2009, 02:24 PM | #9 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
mines at 8 also.
07-31-2009, 02:24 PM | #10 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
I'm at 7lbs 2 oz. for my rig, I my self is at 295lbs. |
07-31-2009, 02:32 PM | #11 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
an ounce shy of 7lbs with an 850mah 3s. so medium not light but not heavy
07-31-2009, 02:35 PM | #12 |
Was at 7+ Now below 6. All my weight was in the wheels. I picked up a light set, kept them light, now I can switch back and forth depending on conditions. I have noticed that the light truck really needs to be lower to keep a good plant... so I have to adjust the shocks a little when running the light wheels. |
07-31-2009, 04:39 PM | #13 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
07-31-2009, 04:43 PM | #14 |
Rock Crawler Join Date: Jun 2008 Location: dublin
07-31-2009, 05:08 PM | #15 |
I have no idea, I really don't care either, I run a little try it with less, if it works better, try a little less, then add, then add some more, then subtract.....
07-31-2009, 05:19 PM | #16 |
I wanna be Dave Join Date: Oct 2005 Location: Under the 4444
You shoulda been a math teacher.
07-31-2009, 05:19 PM | #17 |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
It doesnt matter how much weight you run if your suspension does not compensate for the weight. For instance, I ran my rig with no weight in the wheels but had losi red springs which are heavier than a lot of the others. The rig sucked because it drove like a stick. I added about 12oz. to each front and 9oz. to each rear and that spring rate was perfect IMO. So if you want a light rig or a heavy rig, make sure your spring is right otherwise theres no point to the weight. My rule of thumb is heavy wheels, heavier springs. And lighter wheels, lighter springs. |
07-31-2009, 08:59 PM | #18 | |
07-31-2009, 09:08 PM | #19 |
| 4.94lb on the fancy scale at the hoobby shop. Ok, they are lighter HR axles, KK zero 4.0, traxxas big bores W losi gold/gray, dual fxrs, 4pk, proline slash rear wheels and dna fronts with no weight. It is too light, needs some more wieght in the front. Will end up under 6 easy.
07-31-2009, 09:09 PM | #20 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
I need pics of the 5lb Berg! My Berg was about 7.7lbs when I put in on the shelf, and my plastic axle, plastic wheel, delrin chassis, little 4XX motor MOA RS10 rig is coming in just shy of 5lbs. If you got your Berg down to 5lbs, congrats!! But I got to see some pics of how you did it. edit: nevermind............................the rig in question wasn't even a Berg |
