05-18-2012, 08:52 PM | #1 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
| ~53 willys builds a DLux style Bully/Berg~
never drove a Berg before...I got burned out on 1.9 class so I sold it and built a 2nd 2.2 so me and my son can drive together. after seeing what Dlux has been doing to Berg axles I knew I had to build a berg and not a 2nd XR10..... specs break down like this...... Chassis DLux 2.2 CF truck chassis with full Alum hardware...I believe this is the lightest chassis built at this time. DLux super thin panels Front axle DLux Alum long side tube DLux Delrin short side tube DLux Delrin shock/link mounts DLux Adjustable upper link mount DLux Servo mount DLux Berg motor mount case shave DLux Clear gear cover with lipo mount DLux Milled and drilled gears DLux Larger drive pin mod on all gears DLux Ti drag and tie rod with alum revo ends DLux Modded Super bully axle shafts DLux Bully knuckle weights DLux Steel knuckle weight rings Home hacked dremel locker RC4WD alum bully knuckles with 3m X 8m king pin bearing mod Axial AX10 alum Chubs 14T pinion Built with alum and Ti hardware Rear axle DLux Delrin rear tubes DLux Delrin lock outs DLux Shock/link mounts DLux Adjustable Upper link mount DLux Berg motor mount case shave DLux Clear gear cover DLux Milled and drilled gears DLux Larger drive pin mod on all gears Home hacked dremel locker CKRC rear axle shafts(until I can get DLux shafts) Berg hexs drilled out to 6mm 14T pinion Built with alum and Ti hardware Links DLux Ti 1/8" uppers DLux Ti 3/16" lowers DLux Delrin link sliders Alum revo ends Shocks 2660 Big Bore shocks front/rear Lathed down shock bodies Cap mod with long 3mm revo ends on the front 3mm short revo rod end on the shaft side front Cap mod with short 3mm revo ends on the rear RC4wd angle rod ends on the shaft side rear's CrAwLeR13 "G-cup" mini-T spring cups Pink Mini-t springs F/R Alum revo ends Electronics 4PK Smashed CC Sidewinder Micros with 20g wire CC BEC smashed with a Futaba R604FS(until I get a micro Futaba RX) Brood 35T big wire Lathed AND cut cans alum motor screws delrin timing ring removed circuit boards 20G wire hitec 7955 at 7.0v with robotronic arm micro deans Wheels DLux .7 or .5 wheels alum hardware CF D cut faces VP SLW hubs 600 rear and 350 front Tires Sedona BC's Rovers what ever works at the location I'm crawling at. the whole rig and axles are assembled with alum or Ti hardware. i'm going to gather my pics up and try add get some pics posted soon... |
05-18-2012, 09:18 PM | #2 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
| Re: ~53 willys builds a DLux style Bully/Berg~
Wow quite the parts list should be an awesome build |
05-18-2012, 10:00 PM | #3 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Oh ya this will be awesome! Can't wait to see it Subscribing....
05-18-2012, 10:11 PM | #4 |
Rock Crawler Join Date: Sep 2009 Location: The BYB Compound
you deffinately picked all the right parts to build this berg with. I love all my DLUX parts. waiting for the pics.
05-18-2012, 11:15 PM | #5 |
Rock Crawler Join Date: Oct 2007 Location: south of France
woww lot of Dlux here !!! but I see 20G wire ??? isn't too small ?? |
05-18-2012, 11:34 PM | #6 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
All I have to say is "BITCHIN" Diggin the bully front shaft mod Later, Farmer |
05-19-2012, 12:47 AM | #7 | |||
| Re: ~53 willys builds a DLux style Bully/Berg~ Quote:
you cant go wrong with a Dluxed Berg.....and G-cups Quote:
I'm not real worried about the wire....I figure if my sky 800Mah lipo power wires are 20G then there is really no reason to go bigger then the wire that supplies the rig with power. thanks Farmer....when Erik first built his berg with super bully axle shafts and knuckles I was sold...it is a killer way to build these axles and you save a boat load on after market parts....and if you do have issues with the super bully shafts they are CHEAP to replace....I dont think I will have any problems though, when I ran my bully at 8lbs I never broke the V6 style shafts from RC4wd and this rig will be easily half the weight of the bully. | |||
05-19-2012, 01:00 AM | #8 |
I'm gonna jump right in and show some pics of the micro sidewinder smash... I started with 2 sidewinder micros... I pulled the 16g wire off and completely stripped the esc down...it's amazing how much wire and switches weigh... I married the two esc's with some 20g wire... weight with a BIG piece of clear heat shrink.. Note the bottom esc RX wires feed up through the top esc's old power wire hole. man they get thin when they get married...unlike real married life where its the opposite effect.. |
05-19-2012, 04:56 AM | #9 |
And then? Looking good! |
05-19-2012, 06:13 AM | #10 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
You should go back to your roots and use bully cases. I think it could work? Build is going to look great! |
05-20-2012, 11:34 AM | #11 | |
| Re: ~53 willys builds a DLux style Bully/Berg~ Thanks harvo... Sorry for the delay......801rcc had a comp this weekend and so I did not have time to continue the build....more pics are coming.... Quote:
Well I might have done that but talking dlux into bully tubes was way to much work...lol.....I had already got all my parts from him by the time you some how managed to sweet talk him into delrin bully parts... | |
05-20-2012, 11:52 AM | #12 |
so next was the RX and BEC smash... I'm already running low on the RC slush fund so I'm using the old school HEAVY futaba RX R604FS that I had lying around until I can get a 614 RX still came in pretty small...but not as small as I would like... I just used a couple O-rings to hold the RX/BEC to the two ESC's Note this is the RTR weight..with micro deans and all motor wires So I started with just Two esc's weighing in at 39g's......after weight lose AND adding a RX and BEC I'm only 2g's heaver then the just esc's I think the other 2g's would be gone if I used a 614rx.... |
05-20-2012, 12:06 PM | #13 |
time for some big bore lathe work.... I don't have great tooling for this lathe so I'm sure any REAL machinist on here might not like how I do this but hey it works great for what I have available to me stock 10g's lathed down 7g's |
05-20-2012, 12:19 PM | #14 |
Nice I was thinking of grinding my shocks down a little bit Could you tell us the weight of the full build shock?
05-20-2012, 12:59 PM | #15 |
next was some gear work..... since RCbros alum lockers are not available I had to follow rob_b's lead and mill my stock locker myself........only problem is I don't have a mill so I busted out the 90* angle grind and a rotatory file and then the dremel. I stole this pic from dlux build...I swear I took a pic of my locker stock but I cant find it now....anyways I know the stock locker weighs the same on his scale and mine...we have verified our scales with each others.. stock locker 15g's after I hacked it up.... Next was gear milling...since I dont have a mill I had to hire out Dlux's gear milling service....well worth the $$ While Dlux milled my gears I also asked if he would mill for bigger drive pins... Stock 1.5mm pin on the right, new, bigger 3/32 pin on the left. I also had him mill my motor mount on the case |
05-20-2012, 01:00 PM | #16 |
| Re: ~53 willys builds a DLux style Bully/Berg~ |
05-20-2012, 03:25 PM | #17 |
Where did you source your bigger pins?
05-20-2012, 03:32 PM | #18 |
05-20-2012, 04:20 PM | #19 |
Very interesting Bully/Berg, love the hot rodding.
05-23-2012, 11:14 PM | #20 |
~53 willys builds a DLux style Bully/Berg~ - Similar Threads | ||||
My dlux hall style berg rebuild | CrAwLeR13 | EnRoute Berg | 247 | 09-22-2013 07:48 AM |
~53 willys DLux Style Super Berg~ | 53 willys | Superclass Crawlers | 112 | 01-27-2012 01:05 PM |
~53 Willys Builds a XR10 Beetlejuice~ | 53 willys | Axial XR10 | 140 | 10-15-2011 10:12 AM |
Willys builds | crawl-o-matic | General Scale Talk | 8 | 09-29-2011 10:23 PM |
My DLUX Hall Style Berg | CrAwLeR13 | EnRoute Berg | 27 | 08-03-2011 10:56 PM |
