07-25-2013, 06:35 AM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: SWE
| recommended knuckle weight?
Hi. how much woud you guys say that is needed on the knuckles? building a berg V3 Moa. thanks. |
07-25-2013, 06:45 AM | #2 |
| Re: recommended knuckle weight? |
07-25-2013, 07:52 AM | #3 | |
| Re: recommended knuckle weight? Quote:
well or you coud say: i use in my set up bla bla bla or depending on setup i woud use etc etc say that my axels pure stock 250-300grams give or take. hope that helps regards | |
07-25-2013, 08:19 AM | #4 | |
There is a reason knuckle weights are adjustable. | |
07-25-2013, 08:45 AM | #5 |
07-25-2013, 11:18 AM | #6 |
Youre going to get opinions all over the place on this, as said above.... I personally prefer as much as possible below the axle center line. As of late, I am tempted to even max out my entire knuckle above and below. |
07-25-2013, 01:21 PM | #7 | |
Maxing out with your ultra light weights builds? Thanks. | |
07-25-2013, 02:10 PM | #8 | ||
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
I like one pound combined, way below the front axle...with forward bias. | ||
07-25-2013, 02:57 PM | #9 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
None |
07-25-2013, 05:39 PM | #10 | |
Or 8.5oz Another way to put it would be that I am after your advice, which I cannot thank you enough for.... I have fun crawled with Mr. Gates more than once. Never felt like I had a chance at keeping up with the guy. What is his secret? He let me in on it and told me that it was more weight in the front. I tried it and have never looked back. Probably some of the best advice I have ever received was from this guy. | |
07-25-2013, 05:40 PM | #11 |
Also, I forgot to add,... I run as much weight as possible for my terrain which is long, steep climbs. If I were to run rip rap, boulders or something of the sort, I would pull all that weight back off as I feel a lighter car works better in those situations. |
07-25-2013, 05:59 PM | #12 | |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
Eric kept telling me how great the weight was. And after a comp where I suffered a lot due to lack of front weight I started running 6oz per side. Amazing! So I'm 4lb even with 12oz of knuckle weight. | |
07-25-2013, 06:26 PM | #13 |
So around a 1/4 of your rigs weight should be knuckle weight? That's probably a good starting point anyway.
07-27-2013, 01:21 PM | #14 |
Quarry Creeper Join Date: Apr 2011 Location: Estonia, Europe
08-04-2013, 03:50 PM | #15 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
I run about 4 oz per side. The truck is night and day different with and without the weight. Best thing for you to do is find a practice rock, try to climb it without weight and add weight until it feels like your making progress. I'm now at 4.3/4.4 lbs with that knuckle weight and the truck is super predictable. Erik once recommended a bit of balance and maybe adding an ounce to the rear. I tried for about a week and didn't care for it as much. For what it's worth, it's the only dlux part I've ever taken off my rig ;). The guys in my club ( some of them ) think 8 oz is crazy amounts of weight. It works for me.
08-05-2013, 11:31 PM | #16 | |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
We here in Oregon have every rock one can think off. From slick rock, to rip rap to lava rock. My knuckle weights come on and off constantly. high traction, load that knuckle son!! Low traction, depends on the scenario but I usually just go with a mild forward bias rip rap, light and nimble like a cat drinking milk from a saucer I also have taken or removed weight for one course to the next depending on the obstacles set. This is why I encourage those to not limit themselves on the weight they have available and to play with adding and removing weight to there benefit. How the weight is added in relation to the furthest out on the axle and below the axle center-line is also crucial to how much weight one needs and how it can or will benefit the truck in any given scenario should be taken into account. | |
recommended knuckle weight? - Similar Threads | ||||
Knuckle weight | Cordwood | Axial AX-10 Scorpion | 19 | 10-03-2012 10:17 AM |
Now THIS is knuckle weight | cspyy | Axial XR10 | 22 | 03-02-2012 10:19 AM |
how much knuckle weight? | TedBull | Superclass Crawlers | 6 | 06-19-2011 09:55 AM |
