Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Wantamix, esc wiring help
Old 08-20-2013, 08:10 PM   #1
Default Wantamix, esc wiring help
So I am deep into my Berg revamp and have everything installed, but now I have a couple of issues. I am running smashed brxl's,castle bec, wantamix, spektrum sr3100 receiver, and hs7955 servo.
I think I have everything wired correctly.
I have the esc's run to the wantamix, the wantamix 2 channel run to the throttle plug and the 3 channel run to the aux plug. Bec is plugged into the Bat/Bind plug.And servo in the steering plug. When I plug in the battery I have beeping on the esc's and the receiver is flashing fast and nothing works. When I unplug the bec from the receiver and plug it back in the beeping stops and the steering works but no forward or reverse at all??
Any help would be appreciated.
Thanks
scoutdawg is offline   Reply With Quote
Old 08-20-2013, 08:26 PM   #2
Default Re: Wantamix, esc wiring help
Try asking in the electronics section, you will get more help there.
Tgreer is offline   Reply With Quote
Old 08-21-2013, 07:39 AM   #3
Did you calibrate each of the ESC's to work with your controller? This is simply letting your ESC's know what the full throttle, full reverse, and neutral points are for your radio.
I'm not sure on the blinking light on the Rx though...I'll think about it a little more...
ittybitty is offline   Reply With Quote
Old 08-23-2013, 10:07 PM   #4
Same thing happened to me with the throttle/reverse calibration. Two second fix of that's the real problem
Chwhpa is offline   Reply With Quote
Wantamix, esc wiring help - Similar Threads
Wiring two different esc ? builder Electronics 3 04-30-2013 06:46 PM
Help with wiring new esc 09xD Duratrax Cliff Climber 16 07-30-2009 04:21 PM
