11-05-2014, 08:41 PM | #1 |
Newbie Join Date: Dec 2008 Location: Calgary/Edmonton AB
| Newbie new problem with Berg conversion
I gonna use Dlux front axle tube with servo plate,but I found with Hitch 7955 installed, the motor even can not touch the spur gear with 14t pinion, how did you guys solve this "unexpected bug"? Replace a 17t (more biger)one? thus I have to replace a high turned motor? |
11-05-2014, 08:50 PM | #2 |
Rock Crawler Join Date: May 2009 Location: Calgary
| Re: Newbie new problem with Berg conversion
With this type of servo set-up, you will have to move the motor back and up slightly. Search 86jeep steering. EDIT: Check this 86 Jeep Style Steering - post 17 Last edited by Krawler Kev; 11-05-2014 at 08:53 PM. Reason: Comp crawling will never die |
11-06-2014, 06:12 AM | #3 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
You could also get a set of these cases from DLUX. They will move the motor back so everything clears. Looks like $100 for both cases? It would solve all your problems and all your parts will swap over I believe. Dlux Fab |
11-06-2014, 08:04 AM | #4 | |
| Re: Newbie new problem with Berg conversion Quote:
Stubs is right, a new front box would fix all those issues and then some if you dont want to put the effort into those stock ones. Its not $100, almost half of that for a front box. Dlux replacement cases | |
11-06-2014, 08:11 PM | #5 |
Thanks all above,helping make clear about the problem;I gonna try to fix and cut stock box but no much more confidence,give me 2-3 days to try or sleep on it. Thanks buddy! |
Newbie new problem with Berg conversion - Similar Threads | ||||
Newbie with a problem | Slimp-o | Axial Wraith | 3 | 03-21-2014 11:19 AM |
newbie with a problem | RoyalXJ | Redcat Crawlers | 14 | 06-08-2011 09:03 PM |
What is/was the problem with the MOA conversion? | xgerstandtx | Team Losi Comp Crawler | 38 | 10-27-2010 12:34 AM |
TLT Junfac conversion (Newbie) | gmjeeper | Tamiya TLT Crawlers | 11 | 03-14-2008 07:29 PM |
Newbie help with rock crawler conversion | Marcusg | Traxxas Crawlers | 4 | 07-08-2006 01:12 AM |
