Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Beest's AMX build
Old 06-07-2015, 12:25 AM   #1
Default Beest's AMX build
Most of yall know me, I've been building and running comp crawlers since late 2008. I've never done a build thread until now. So here goes.....
Most of y'all also know Barrybelvedere, he's been at this just as long as I have. He just started selling carbon fiber parts, motor guards, steering arms, four link plates, and now chassis!
Now that were up to speed. On to my build. I'll start with the required parts list.
For esc's I'm running 2 Castle sidewinder micros. Motivation is brought to you by 2 Holmes hobbies 16t skewed arm crawlmasters.
Steering is handled by a Hitec 7950 powered by a castle bec set at 8.4 volts.
All ran by my trusty old futaba 3pmx and a wannamix. I will be upgrading the radio gear as soon as my budget allows.
Axles are berg gear cases and gears with tubes from Dlux.
The front is loaded with O.G. super 300 shafts, Axial axle C hubs, Vanquish 0 ackerman high steer knuckles, and finished off with Dlux knuckle weights.
The rear axle has delrin tubes, the gears are drilled, and I've installed a RC bros locker. Axle shafts are Dlux aluminum big ol' shafts.(strong and light!)
On to the pics of progress from tonight.
Work space all prepped to start.
Old chassis, carnage from gate 4 of the finals course at ECC. My rig fell about 30 feet down a cliff while I was trying to bump up a particularly slick climb.
Drilled out my rear gear set. Going to do the front gears tomorrow.
Axels cleaned up from ECC. If y'all didn't make it out, it was a wet one this year, the rigs came home dirty.
The end of progress for tonight. I'm waiting on my new Ti lowers to show up and I'll be doing more tomorrow.
Thanks for looking. Comments are welcome!
Beest is offline   Reply With Quote
Old 06-07-2015, 04:33 AM   #2
Default Re: Beest's AMX build
was that the DD chassis you did break at ECC??
FLOKI-81 is offline   Reply With Quote
Old 06-07-2015, 07:03 AM   #3
Yes. A modified version. Barry made it to work on a set of berg axles. The o.g. DD wouldn't work on bergs, the shock spacing was to narrow at the chassis.
I liked the DD chassis. It worked well. Stuck to about anything. It got me a 5th in 2.2 pro at ECC. The only reason I didn't do better was bad decisions on my part.
Old 06-07-2015, 04:38 PM   #4
A good start....I think that fall was way more than 30 ft. I figured some how you started after me and finished b4 me. You gotta wake up PRETTY EARLY if you want to finish before me....LOL
barrybelvedere is offline   Reply With Quote
Old 06-07-2015, 04:44 PM   #5
Its not hard to wake up earlier than you, sleepy head.
Old 06-07-2015, 11:28 PM   #6
Fifth dimension
Crawllife's Avatar
Killer start. I can't wait to see this one in person. Thanks for helping the berg section with a build thread!
Crawllife is offline   Reply With Quote
Old 06-08-2015, 01:48 AM   #7
Ok.... i stayed up till 3 A.M.! Finished my XR-10 RE-built/ New chassis thread! Also finished my Jar of Moonshine too. And ok That drop at ECC was probably closer to 3 story fall not 60 feet. Any rig would have been broken at that height. Oh well now you got a Sweet new Chassis.
Old 06-08-2015, 08:51 AM   #8
Looking good Beest! New chassis and a build thread finally! Can't wait to see it in action in Vegas!
mammoth is offline   Reply With Quote
Old 06-08-2015, 01:37 PM   #9
Thanks Randy. It'll be good to see y'all.
Old 06-09-2015, 08:29 PM   #10
So little update. I drilled my front gear set. For any of y'all who want to do this, use a 3/16 drill bit. Most folks these days buy pre lightened gear sets
But for those of us who are do it yourselfers, or just cheap like me, it's easy enough to do. First take the small gears out of the larger ones. Then put Em in a vice so the pin slots run parallel to the vice jaws. Get the vice good and tight so that when the bit goes to grab when it's about to break through it won't let the drill pull it loose. Then grab your 3/16 bit and carefully line it up straight up above the hole for the small gear. Take care not to get to close to the edge of the gears. Then drill through. After you have a hole, line up your bit so it's as close as you can get to right between the hole you just drilled and the pin slot. Then drill through. Repeat on the other side of the first hole and your done on that side. Flip gear and repeat. Mine didn't turn out perfectly, but they will do.
Not as nice as some but good enough for who it's for.;)
Old 06-09-2015, 08:30 PM   #11
Complete drilled front gear set.
Not as nice as I hoped but it'll do.
Old 06-09-2015, 08:37 PM   #12
I also got some better pics of the chassis. My old android camera has seen better days so I'm using my wife's iPhone. Lol
These are the lipos I'm using this season. Good punch and good price 8$ each iirc.
Old 06-10-2015, 11:49 AM   #13
$8 power. I like it. Was out of stock though.
KBrog is offline   Reply With Quote
Old 06-10-2015, 01:36 PM   #14
Keep checking back. Good dealzzzz
Old 06-13-2015, 08:34 PM   #15
I looked for the same packs. still out of stock
Old 06-13-2015, 09:34 PM   #16
My new links should be in by Monday, then I should have some progress to report.
Old 06-16-2015, 04:12 PM   #17
I just checked Value hobby today for thoes 50c 500mah packs. They were in stock so i ordered 2 of them.
Old 06-16-2015, 04:14 PM   #18
Sweet. My links showed up yesterday so I should have an update soon. I'm working on the Cummins as of now.
Old 06-16-2015, 04:20 PM   #19
You aren't going to be ready or have the funds for the NENC if you keep dumping time and $ into that dodge
Old 06-16-2015, 04:27 PM   #20
I won't be able to eat or pay my bills, if I don't fix it. Its just the lil plastic bushings in the wiper assembly.
Beest's AMX build - Similar Threads
BarryBelvedere's XR-10 RE-Build w/ The NEW AMX Chassis!!! barrybelvedere Axial XR10 101 03-20-2016 11:18 AM
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) Irishchamp 2.2 Scale Rigs 45 10-09-2014 10:26 PM
Jeep scaler build and comp micro crawler build droopmodmrc Losi Micro-Rock Crawler 1 12-25-2012 12:34 PM
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ 53 willys General Crawlers 108 11-28-2011 12:42 AM
