01-06-2013, 11:29 PM | #1 |
Pebble Pounder Join Date: May 2009 Location: big lake
| Project FRANKENSTEIN "FRANKY"
I live in ALASKA and we get lots of snow and This is something I have been wanting to try for awhile, so when the 4x4 slash came out it got super easy plug and play. I had a slash and my wife had a slash both had vxl systems so thats where the trannys and power plants came from. From there the only parts bought were slash 4x4 front hubs , hub carriers ,steering bellcranks,drivelines and axles. Plus 2.8 proline desperado wheels and sandpaw paddles. The rest of the parts came out my parts box or I made what I needed I still need to paint the body but its been to cold outside to paint, so I will use my wifes old bug body for now. Heres a list of some of the other parts I used. Traxxas rustler upper chassis Traxxas slash 2wd front skid with the the steering post on it aluminum nitro stamped rear a arms because I had them but you could use slash 4x4 front a arms. 1/16 aluminum plate 1/16x3/4 aluminum angle 1/8x2in flat bar 1/4 brakeline 1/2in hdpe plastic 1/8in hdpe plastic I took the 1/2in hdpe and cut it as close to 30 degrees as I could by hand to put under the tranny to adjust for the anti squat. Then I took mounted the front tranny to the 1/8 x 2in aluminum flat bar then found my wheel base then mounted the rear tranny. Then I took the 1/16 aluminum plate and made the tub. I used the 2wd slash front skid plate to hold the steering bellcranks and rustler upper chassis plate to hold the steering servo and to lock the bellcranks in place.Then I took the 1/16 x3/4 aluminum angle and used it to help hold the batteries in place and stiffen the chassis. And the 1/4in brakeline to help stiffen the shock towers. Heres some pics for now will get more soon |
01-07-2013, 03:41 AM | #2 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: Project FRANKENSTEIN "FRANKY"
Nice work . The only thing I would worry about is that chassis filling up with sand or snow unless you have a cover for it.
01-07-2013, 07:52 AM | #3 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
nice idea!
01-07-2013, 08:28 AM | #4 |
| Re: Project FRANKENSTEIN "FRANKY" |
01-07-2013, 08:29 AM | #5 |
01-07-2013, 05:02 PM | #6 |
Newbie Join Date: Jan 2012 Location: New Orleans
I like the thinking-out of-the-box idea. Is it fast with 2 motors? What size batteries are you using? Lastly, how do those tires hold up with ballooning or not tearing apart?
01-07-2013, 06:54 PM | #7 |
or maybe some foam or something from walmart
01-07-2013, 08:21 PM | #8 |
| Re: Project FRANKENSTEIN "FRANKY" Thank you. Yes it is faster and the nice thing about 2 motors is you can gear the front to go faster then the rear so it helps pull the truck around corners and up hills. I'm using 2 5000 2 cell 30c-40c lipos. The tires are working great they balloon some,but they seem to be tough enough. Plus the width helps it float on the snow.
01-07-2013, 10:13 PM | #9 |
Here are some pics of FRANKYS frist test run. Like I said in the begining I'm using my wifes old bug body for now. I'm really happy with it. I ordered a outerwears cover for it tonight should be here soon |
01-09-2013, 06:48 AM | #10 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Nice job. looks like it's solid.
01-09-2013, 07:47 AM | #11 |
01-09-2013, 08:56 AM | #12 |
Rock Crawler Join Date: Mar 2010 Location: Onalaska
I like it good thinking.
01-09-2013, 09:24 AM | #13 |
I like it!!! |
01-09-2013, 11:51 AM | #14 |
Pebble Pounder Join Date: Sep 2011 Location: South Africa
Looks nice dude, well done
01-09-2013, 02:45 PM | #15 |
RCC Addict Join Date: Aug 2011 Location: Pipersville
Awesome pictures..
01-09-2013, 10:35 PM | #16 |
01-09-2013, 10:35 PM | #17 |
01-09-2013, 10:37 PM | #18 |
01-09-2013, 10:45 PM | #19 |
01-10-2013, 02:38 PM | #20 |
Can you get some video?
Project FRANKENSTEIN "FRANKY" - Similar Threads | ||||
Project "Clampy" 1.9" Scale Yota Build | 51WillysJeep | 1.9 Scale Rigs | 717 | 08-09-2019 05:58 AM |
AREA 51RC "Project Chaotic "Switch" XR10" | D19er | Axial XR10 | 105 | 03-10-2014 05:30 PM |
Project "Tombstone" R.I.P "Rest In Pieces" | mud digger | 2.2 Scale Rigs | 25 | 05-20-2013 07:54 PM |
Project "FRANKESTAIN" or "AXIAL FORCE" | mykonian | General Crawlers | 5 | 03-06-2009 11:37 AM |
Project "TimberWolf" 1.9" Scale Yota Hybrid | 51WillysJeep | 1.9 Scale Rigs | 53 | 08-14-2008 06:43 PM |
