Go Back   RCCrawler Forums > Miscellaneous > Formula Offroad
Thread: Twin Hammers
Old 05-07-2013, 06:34 AM   #1
Default Twin Hammers
I searched nothing came up has anyone tried make a Twin Hammers into a Formula Offroad yet ?
xCoolHandLukex is offline   Reply With Quote
Old 05-07-2013, 06:55 AM   #2
Default Re: Twin Hammers
I don't think anyone has yet. From what I've read they are not as tough as expected. It would be interesting to see a build, butmaybe aftermarket companies need to start producing tougher parts.
M1tch is offline   Reply With Quote
Old 05-07-2013, 01:10 PM   #3
Be aware that the steering set up won't take alot of abuse.
stelerzman is offline   Reply With Quote
Old 05-07-2013, 01:24 PM   #4
9 posts down
What do you guys think?
1tonscout is offline   Reply With Quote
Old 05-07-2013, 06:22 PM   #5
Well his pics convinced me. Ordered a twin hammers, paddles, all the aluminum upgrades, front locker, F and R sway bars, hitec 645mg shift servo, Hitec 7954 with a bec for steering. I want to put an SV3 with a 4600kv in it but I can't find one in stock so I'll have to wait. In the mean time I have a spare traxxas VXL setup I could try. I see there are some vanquish kits to run different axles I'll look into that.
Old 05-07-2013, 07:49 PM   #6
You may want to pick up a set of HR steel gears for the trans as well as a Losi 3907 51t 32p spur for it.
Exocaged is offline   Reply With Quote
Old 05-07-2013, 08:20 PM   #7
Where do you get the HR steel gears ?
Old 05-07-2013, 08:28 PM   #8
CKRC has the HR gears.
mjyjxj is offline   Reply With Quote
Old 05-07-2013, 08:55 PM   #9
Never mind found some in stock. Think I should lock the front diff or go with really thick oil ?
Old 05-07-2013, 08:57 PM   #10
If I remember right I got mine from Hobby etc. That Losi spur is a direct fit as well, reuse your stock slipper and all. The cover even fits. Smallest 32p pinion you can run is 14T.
Old 05-07-2013, 10:40 PM   #11
Try them both and let us know what you think.
Old 05-08-2013, 06:46 AM   #12
I found an SV3 4600kv combo on eBay so I should have everything in a couple weeks. The only thing I need now is rims. I ordered sand paws and panther paddles. Any recommendations on what rims to run ? I'd like to get as much offset out of the rim as possible.
Old 05-08-2013, 07:54 AM   #13
Check into Prolines beadlock wheels for a Traxxas Slash. I had them on Speed.Demon for over a year with out a single striped hex.
Old 05-08-2013, 12:33 PM   #14
Will panthers and sand paws fit on the proline rims ? From the pic it looks like there traxxas short course style so I would need to order the proline slingshots I think.
Old 05-11-2013, 09:27 PM   #15
Ordered the vaterra made locker, the aftermarket locker, 300k and 500k diff fluid so I'll try them all. I also ordered the Traxxas 1/16 cantilevers in both regular and long travel, the blue monkey stage 2 kit, the Losi gear and spare front and rear axles plus a spare drive shaft (I got the MIP one on preorder) This is fast approaching my most expensive build yet and I don't even have the Twin hammers yet LoL. I hope I like Formula Offroad or there's going to be a smoking deal on an upgraded Twin Hammers in a couple weeks.
Old 05-11-2013, 10:51 PM   #16
They should fit, they're the same size as the sand paws. Right?
Twin Hammers - Similar Threads
Yet Another Twin Hammers Tin Soldier Vaterra Twin Hammers 12 02-19-2014 08:47 AM
Savage00's Twinny Twin Twin Hammers Savage00 Vaterra Twin Hammers 16 09-19-2013 09:09 PM
twin hammers zim35 Scale Comp Rules 264 05-19-2013 10:54 PM
Twin Hammers in Twin Cities? 89XJ Minnesota 7 05-06-2013 03:59 PM
