07-19-2010, 12:33 PM | #1 |
Rock Crawler Join Date: May 2010 Location: San Antonio, TX
| Need some new drive shafts!
I took my R1 out yesterday for a good run in a local spot and finally something gave out. The drive shafts popped out twice while negotiating some obstacles. I want to buy some strong shafts to replace the sock ones. A local crawler gave me the name of a company that makes some strong metal ones but I forgot the name. Anybody have any suggestions?
07-19-2010, 12:40 PM | #2 |
Quarry Creeper Join Date: Aug 2009 Location: Malta
I'm going to try these... still in the post though so no idea on quality or if they are any good http://www.junfac.com/shop/index.php...5fc96ff3f6d2dd |
07-19-2010, 12:43 PM | #3 | |
07-20-2010, 01:05 PM | #4 |
Newbie Join Date: Jun 2010 Location: sydney, Australia
the junfac ones look super soild but im a bit worried about how it joins to the transmission. its has 2 grub screw on either end which dont go all the way in, it just sits on top of the counter sunk hole where the stock one has a pin that goes all the way through. so they sit about 2-3mm into that hole not all the way in. im worried it will strip the grub screws and then ill be in real trouble!! hope you know what i mean. also im running the dig as well and the plate that is connected to the tranny has one grub that only goes in one side on the plate but ill find out soon how it works, my motor and other bit should be in in the next couple of day so maybe this weekend ill get mine running. ill post some pics later when i get home if you guys want
07-20-2010, 01:10 PM | #5 | |
Ultimate RC Decals Join Date: Aug 2005 Location: San Antonio
http://rc4wdstore.com/2/index.php?cP...dd576edb1764a5 | |
07-20-2010, 01:26 PM | #6 | |
| Quote: | |
07-20-2010, 01:38 PM | #7 |
GOD DAM! they look good
07-20-2010, 01:43 PM | #8 |
07-20-2010, 02:22 PM | #9 |
i ran them on my comp rig back when i ran a shaty rig. i had no problems with them. i was also using them on my hilux and should've have shown you them sunday.
07-20-2010, 09:53 PM | #10 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
The Junfac shafts are fine. Nice and strong. I run them in my axial comp rig. If you are worried about the stay pin not going through the outdrive just use the pin from the stock shafts and run it through the new shaft. |
07-20-2010, 09:56 PM | #11 |
Hey guys, check out what I did to my stock ones for a temporary fix: http://www.rccrawler.com/forum/showt...33#post2551733 |
07-21-2010, 10:59 PM | #12 | |
Quarry Creeper Join Date: Jan 2010 Location: UAE in the GCC
| Quote: now these are some nice looking drive shafts!!!!!! i dont see these things coming off ..... it'll break something but i'm definite it won't pop off ..... thanks for the link Last edited by strawb; 07-21-2010 at 11:03 PM. | |
07-27-2010, 03:06 AM | #13 | |
| Quote: | |
07-27-2010, 08:30 PM | #14 |
| I went with the Gmade! Non of those are specific for the R1 but you can measure the stock ones and order based on the measurement.
07-27-2010, 10:33 PM | #15 | |
thanks ..... i got a dig unit installed and it might be a problem if i dont get the right dimensions ..... cutting and all that chit .... the junfacs look solid enough | |
07-28-2010, 07:07 AM | #16 |
08-14-2010, 11:04 AM | #17 |
Newbie Join Date: Apr 2008 Location: Orange County, Ca
I was popping the stock drive shafts. I installed the Junfac one's and have not had a single failure. Now I'm breaking the front outer axles Looks like I need to get rid of the 13.5 motor |
08-14-2010, 06:29 PM | #18 |
| I also installed Junfac's and I've had no issues so far! I like them. Last edited by Oso787; 08-16-2010 at 03:53 AM. |
08-17-2010, 12:38 PM | #19 |
Newbie Join Date: Aug 2010 Location: Nacogdoches
Looks like MIP needs to get busy^^
