10-03-2010, 08:06 PM | #1 |
Newbie Join Date: Sep 2010 Location: HONG KONG
| Stock Tires so Hard ,,,
Please advise some for me ... please in advance ! Afer fixing the upper link problem , all work fine .. http://www.youtube.com/watch?v=IbfevzcmaAc |
10-04-2010, 06:56 AM | #2 |
Quarry Creeper Join Date: Aug 2009 Location: Malta
read through the following topic... tyres i ended up buying the HB Rovers and they are very good. Only issue i had was that i found the foam to be too soft and also i had drilled holes in the rims for air. Now all is fine...closed holes again and used the gmade foam instead. |
10-04-2010, 09:57 AM | #3 |
Thanks for your reply. I will try the SCX one in the next event. Now , I put the original gmade foam and cut some V grooves on there. I hope that it can make the tyres to be more soften. |
