01-14-2012, 06:08 PM | #1 |
Quarry Creeper Join Date: Oct 2010 Location: Nashville TN
| R1 battery placement
For those not running the battery on the axle, where does it mount? Ill probably use 1600mah 2s packs around 100mm x 30mm x 15mm i dont want to run it on the axle, will a pack that size tuck into the chassis easily?
01-15-2012, 09:27 AM | #2 |
Pebble Pounder Join Date: Apr 2011 Location: Liverpool Y.N.W.A.
| Re: R1 battery placement
I put my lipos just behind the driver/rear part of the cage.... One under the tray and another above it. Your battery should fit fine, it may stick out the back but it depends on how far you shove it in..... Last edited by Dam; 01-15-2012 at 09:34 AM. |
01-16-2012, 08:08 AM | #3 |
RCC Addict Join Date: Jan 2010 Location: Vermont
Yes, I have mounted mine behind the tranny on the supplied battery tray. I have also mounted mine under the hood on a custom made tray. I found the 3s 1300s to be a perfect size for tucking them away. No overhang. Good luck. |
01-16-2012, 01:22 PM | #4 |
Pebble Pounder Join Date: May 2011 Location: Uk
I use the battery tray that came with it, i use these batteries they are pretty small and i get about 45-60 min run time which is plenty and they are as cheap as chips so you can buy a few, i also have mounted them over the front axle, also if your creative with your esc/receiver locations it can give you more options.
01-17-2012, 01:07 PM | #5 |
Newbie Join Date: Nov 2005 Location: loudon
This help answer some questions i had thanks
01-20-2012, 04:22 AM | #6 |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
Under the hood on a custom tray is the best way to go in my opinion |
01-22-2012, 01:10 PM | #7 |
Newbie Join Date: Jan 2012 Location: Biggest little city
i have a 3s and put it under the rear tray and pushed it as far forward as possible. seems to work well for me
R1 battery placement - Similar Threads | ||||
Battery placement ? | bluenosegoat | Venom Creeper | 5 | 02-21-2011 08:55 AM |
Battery Placement | HossManny | Newbie General | 5 | 06-20-2010 04:39 PM |
battery placement | that4byguy | 1.9 Scale Rigs | 3 | 12-18-2009 09:14 PM |
Battery Placement | twisted | Tamiya TLT Crawlers | 6 | 12-08-2006 10:20 PM |
Battery Placement | jetboat | Traxxas Crawlers | 4 | 12-27-2005 04:55 PM |
