06-05-2012, 07:10 PM | #1 |
Quarry Creeper Join Date: Mar 2010 Location: Massachusetts
| Couple questions for the g made experts
Hey folks, long story short, a while back i sold my r1, and have missed it ever since. recently i was thinking of buying some sort of buggy or wraith for just a fun side project. i found that r1's were readily available along w/ a lot of hop ups that weren't around when i had mine. i recently ordered a r1 kit and delrin skid plate to inboard the links. i'm also looking into picking up all the upgrades made by gmade for the rig (link mounts, carriers, bent links, etc.). SO, when i bought my last one, it was already assembled, and had some mods done. i'm just wondering what spares to pick up, what breaks easily, and do they come with bearings or bushings in the kit? i only ask cause they sell a complete bearing set and wasn't sure if it was an upgrade or just oe stuff. also, do the 7* hub carriers help anymore than stock? i understand how they work, but most of my option carriers have been closer to 20* than 7. thanks for any help! -bryan Last edited by bryco13; 06-05-2012 at 07:13 PM. |
06-06-2012, 11:04 AM | #2 |
Newbie Join Date: Apr 2012 Location: Bradenton
| Re: Couple questions for the g made experts
Driveshafts! the stock ones are junk! Especially if you have any power at all.
06-06-2012, 06:05 PM | #3 |
ordered the jun fac steel ones in addition to all the alum. bits. thanks man!
06-06-2012, 06:49 PM | #4 |
Pebble Pounder Join Date: Feb 2011 Location: kelowna Canada
couple of extra dog bones
06-06-2012, 10:41 PM | #5 |
Newbie Join Date: Apr 2012 Location: Phoenix
| Re: Couple questions for the g made experts Stock parts to have extras of... Wheel axle - GM5117 Front Portal Gear Shaft - GM51114 Counter gear - GM51204 Bevel Gear Set - GM51109 Front & Rear Portal Gear Sets To replace things that are OE and no good... ProTek 5x11x4mm bearings to replace stock 1150s Traxxas 5x8x2.5mm Oilite Bushings to replace stock 850 bearings everywhere accept transmission. Traxxas stub axles pins to replace stock ones that break instantly. As for your question about the 7 degree chubs, I love them. When I added the adjustable upper link and adjustable link mount, there was far too much caster. The 7 degree fixed it perfectly so no fooling with links. Plus I really like the aluminum chubs period. My favorite upgrade was the Skid Plate. On my other crawlers I would always hate that my pumpkin would get scratched to hell and this solves that. Plus, I was amazed at how much it helped sliding over obstacles. |
06-07-2012, 06:41 AM | #6 |
yeah i had the aftermarket skid plate on my 1st one, so i made sure to add that to the list of goodies. i appreciate the help guys, i've been searching this section but all the mods and upgrades are so scattered, i was hoping there would have been a top stickied thread of r1 upgrades/mods. looks like some packages should be arriving this weekend, so after my comp on sat, i should be able to get it built or at least get it started. really looking forward to a build. -bryan |
01-06-2013, 07:58 AM | #7 | |
Newbie Join Date: Jul 2012 Location: The I.E.
| Re: Couple questions for the g made experts Quote:
I have just ordered my R1 from CKRC. From reading around the forum I see that the bearings are a high failure item. I want to replace with a better quality bearing but I was wondering what is the count on the 5x8 and 5x11 respectfully? Thanks! | |
01-14-2013, 04:48 PM | #9 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| Re: Couple questions for the g made experts Here is the GMade R1 PDF manual. 51503 850 = 22 1150 = 14 51114/51117 - Get 4 of these as back-ups unless you decide to change to CVD/XVD axles. (Mod thread) Last edited by offroadace; 01-14-2013 at 10:09 PM. Reason: Added XVD Mod thread link |
01-14-2013, 05:01 PM | #10 | |
If you end up working on the trans/belly area this skid plate mounting is horrible. I modded it by drilling out 2 additional holes in the base-plate and threading into it directly and not dealing with the trans mounting screws, I left those stock. It was just a PITA to get everything aligned all the way through to the trans. I also added the Axle Skid plates F/R. Quote:
01-14-2013, 05:09 PM | #11 | |
I dig this idea. I'll have to get some of these and replace the bearings that seem to wear out REALLY FAST!! Quote:
01-14-2013, 08:20 PM | #12 |
Quarry Creeper Join Date: Jun 2012 Location: Port Coquitlam, BC
Awesome thread, I was about to order some hop up items from Junfac and was wondering what spares to get at the same time. Wouldn't seal 5x8 bearings be better then bushings? I can't see them lasting that long in the axles. I would imagine they see almost the same load as the transmission bearings. |
01-15-2013, 07:37 PM | #13 | |
Quarry Creeper Join Date: May 2010 Location: rock hill
Awesome post. Weird thing is, I sold mine last spring and regretted it ever since. I just ordered a new one last Sunday and can't wait for it to get here!! RC Planet has them for 255.00 free shipping and free Junfac driveshafts. I am starting with the delrin center skid. I'm debating on shocks right now too. | |
01-17-2013, 06:21 AM | #14 | |
Newbie Join Date: Nov 2012 Location: Central
01-17-2013, 02:07 PM | #15 |
I'm sure it's been thought before...how about sealing up the axle and fill the thing up with hypoid oil. should extend the life of everything in the axle. More drag and weight but... Pros and cons to everything. Just thinking out loud.. Lol |
02-25-2013, 04:37 PM | #16 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
bushings are the only way to go. on the smaller portel gears only place I needed them. |
02-27-2013, 07:32 AM | #17 | |
Pebble Pounder Join Date: Dec 2012 Location: Utah
Couple questions for the g made experts - Similar Threads | ||||
a couple of scx10 vids i made | ax10newguy | Scale Videos! | 3 | 07-01-2010 04:57 PM |
I want one. A couple questions though. | fusebmx13 | Losi Mini-Rock Crawler | 6 | 01-09-2009 01:22 PM |
couple questions | octigonwallrus | Newbie General | 2 | 04-30-2006 10:49 PM |
Couple videos of our nylints & home-made course... | jeepin_junkie | Videos! | 9 | 02-11-2006 05:27 PM |
Couple Questions | Skratch | General Crawlers | 20 | 09-04-2004 10:10 AM |
