08-01-2012, 08:34 PM | #1 |
RCC Addict Join Date: May 2012 Location: The Volunteer State
| Gmade Stock To Stage 1
After owning my R1 for quite some time now I have finally tapped into the aftermarket world and upgraded mine to what I call a stage 1. I ordered the following list of parts from RPP and installed them this afternoon. Aluminum skid plate Adjustable Upper Link Mount x2 Aluminum C Hub Carriers Aluminum Straight Axle Adapters Aluminum Heavy Duty Steering Rods Aluminum High Clearance Links ( lower ) And now for the transformation pictures from stock to where it sits now. Stock setup Stock Underside Chubs, Upper link mounts Front lower links Rear axle with upper mounts and lower links Skid Plate ( much needed ) New stance with Vanquish 2.2 SLW-1 Respuns with Interco TSL Super Swampers articulation shot 1 Articulation shot 2 To get rid of the "turtling" problem I ordered the make your own packs from maxamps, and plan on making 3 2S batteries and lowering the CoG to correct the problem |
08-02-2012, 12:54 PM | #2 |
| Re: Gmade Stock To Stage 1
Update: 8/1/12 After a good 3 hour testing yesterday I have decided to jump to the next level with my R1 and I ordered even more parts for it from CKRC: Gmade R1 Rear Steering Kit Aluminum C-Hub Carrier (2) for R1 Axle R1 Heavy duty front steering rods Stealth Rock Crawling Chassis for Gmade R1 Rock Buggy Gmade Team ZERO Shock Red 104mm Ax-10 Fully locked Metal Gear Transmission Since the R1 stealth chassis supports both a stock Gmade tranny or an AX/SCX tranny I will be converting over to the AX and going with a Goat 3S esc paired with a ballistic 21.5t brushless motor. |
Gmade Stock To Stage 1 - Similar Threads | ||||
Junfac Gmade XD Piggyback Shock 103mm (2) In Stock | RPP Hobby | RPP Hobby | 5 | 08-23-2012 10:06 PM |
Stage 2? | KRAWL | General Crawlers | 9 | 08-20-2009 08:27 AM |
Stage 2 | quads4_life | Axial AX-10 Scorpion | 0 | 11-19-2007 07:43 AM |
stage 3 of my crawler! The stock chassied wonder | Harris | Tamiya TLT Crawlers | 9 | 08-03-2005 12:04 PM |
