Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Dravpnir tries to build something all weather fun
Old 03-07-2014, 01:47 PM   #1
DravTech
Dravpnir's Avatar
Default Dravpnir tries to build something all weather fun
I have had a pair of R1 axles for a while now, but got so disappointed in the steering that they have just laid in my parts bin almost since I bought them.
I plan to have these one completely waterproof and I do not care that much how it will preform or if it fulfills the rules for some special class, it is more of a fun project. I try to use as much as I can from my parts bin, so there will be quite a lot of axial parts that are leftovers from my sporty that I am building.
Front axle got home made spline adapters, axial universals, some chinese brand Wraith c-ubs, VP wraith knuckles and Hulksta carbon fibre steering arms.
The servo mount will be replaced by a carbon fibre one and I am planing on making a box or something similar to have the battery mounted on the front axle.
The rear axle is a stock R1 rear axle.
The transmission will be a Axial AX10 with Robinson candy inside and RCP Crawlers Titanium shafts. The motor plate is a CF one from NCD. The drive shafts will be Axial wild boars. The motor is a old HH 454 Cobalt Puller. I got a couple of them so I will try to see if they work.
The chassis will be a stock R1 chassis. The skid plate was missing when I bought it and I haven't decided if I am gonna make one myself of buy the R1 delrin skid plate. I will probably order some of those R1 lights anyway. I got some 0.4 mm titanium plates at home that I am thinking of using for panels, but not sure yet. Perhaps I will just go with painted stock panels.
Almost done
I have ordered a set of Mickey Thompson "Baja Claw TTC" 2.2 tires, 93 mm Gmade piggy back shocks, waterproof sanwa receiver and servo. Thinking about using a Sidewinder V3 as esc.
Also need to purchase some more 4 mm diameter titanium to make links and a set of wheels.
Dravpnir is offline   Reply With Quote
Old 03-10-2014, 05:52 AM   #2
Looking forward to seeing how this build progresses.
BadWagon is offline   Reply With Quote
Old 03-19-2014, 03:25 PM   #3
DravTech
Dravpnir's Avatar
Default Re: Dravpnir tries to build something all weather fun
Thanks
Time for some new pictures.
I was surfing around for some parts and got intrigued by the Vattera Twin Hammers Trailing arms for the rear axle. So, I ordered a set and they are a keeper
My plan was to use some Gmade Piggy back shocks so I bought some from Rcmart on ebay but got told after a while that they were unavailable... so I will stick to the SCX10 shocks I got at home.
I think the TH trailing arms looks really promising. With the SCX10 shocks I get horisontal lower links at full extension.
Keeping a wheel base at 12.5" it looks like this. If I can make the skid plate quite thin then I can have straight drive shafts at ride height
I got a bit worried about the ground clearance if I was going to use horisontal lower links, but when I took out the wheels my worries disappeared
Old 03-19-2014, 06:24 PM   #4
supermoturd's Avatar
I've been waiting for updates. Keep them coming!
supermoturd is offline   Reply With Quote
Old 03-22-2014, 02:00 PM   #5
DravTech
Dravpnir's Avatar
I will do my best
And talking about updates...
The electronics has arrived!
Same with the tires. I have put them on some old wheels. I would like to get some new wheels that are more narrow, but think I will start with these and save up some cash to get some nice wheels.
Didnt find any 4 mm titanium at home so I had to go with 6 mm. I guess they will last a very long time
With those and some m3 threaded roll to mock up some upper links I got this.
Throw on the wheels and I have a roller. I have just over 60 mm under the skid (or atleast where it will be when I have made it...) and axles
Old 03-24-2014, 01:07 AM   #6
dont forget the body braces where the shocks mount
the front tends to flex a bit
looks good
cant wait to see the art work for the pannels haha
cabron is offline   Reply With Quote
Old 03-24-2014, 03:03 AM   #7
DravTech
Dravpnir's Avatar
looks good
Thanks
I am still thinking about the bracers. There will be some, but I dont know how I want to make them, or just go the easy way and buy them.
Regarding panels, I am kinda leaing towards ones out of 0.4 mm titanium without any art work. I think the raw titanium color would be a nice together with all the black and silver from the chassis.
Can anyone recommend some beadlock wheels that are max 1" wide and look atleast bit scale-ish and do not cost a fortune?
Old 04-08-2014, 03:10 PM   #8
DravTech
Dravpnir's Avatar
Got home an order from JunFac the other day, so one more step done to make it drivable
Time is limited atm for me so I took the easy way and bought the original delrin skid plate and the shock bracers.
But got an itch to make is 4WS too... but first I want to make it RTR... I think...
The lights one the roof is really bad for roll over capability but they look too cool not to use
Old 04-08-2014, 10:41 PM   #9
Love what you're doing here. It looks great. I've done something similar but with different axles. Thought you might like to see it. Keep up the good work man.
strato54 is offline   Reply With Quote
Old 04-14-2014, 03:29 PM   #10
DravTech
Dravpnir's Avatar
Thanks
And thanks for the picture, it gave me some inspiration
Got my new wheels today. Much better looking and much better width
Old 04-14-2014, 03:44 PM   #11
I'm digging those wheels!!
Old 04-15-2014, 04:51 PM   #12
DravTech
Dravpnir's Avatar
Same here
I actually mostly bought them becuase they was cheap, beadlocks and in the right size... but when they arrived I got really surprised how good they looked. I have also pimped them up with some silver scale hardware and red caps from Gmade.
Old 04-15-2014, 04:55 PM   #13
What wheels are they? GMade?
Old 04-15-2014, 05:18 PM   #14
Looks Good,the links being parallel to each other and the ground
should make the rig handle nicely.
Do the portal axles have gear reduction?
4.3 Zook is offline   Reply With Quote
Old 04-15-2014, 05:29 PM   #15
Love what you've done with the steering on the front axle, I had a set of r1 axles and the turning circle was very disappointing, and have recently been thinking about trying an xr10 conversion on some, now we know it can be done, to the previous poster yes they do huve reduction in the hubs.
greenjk is offline   Reply With Quote
Old 04-15-2014, 07:32 PM   #16
I am really enjoying watching this come together. Post up some more detailed pix of the behind-the-axle steering setup! I want to see how the tie rod clears the lower links and drive shaft!
Old 04-15-2014, 08:11 PM   #17
Any chance you'll be making more of those spline adapters?
May be interested in a set if that happens!
cytogen is offline   Reply With Quote
Old 04-16-2014, 12:25 AM   #18
DravTech
Dravpnir's Avatar
The wheels are Mickey Thompson MT-28 Internal Beadlock Stamped Metal wheels from RC4WD. They are made from steel so they are quite heavy, but for $55 for a set and that I am not going to comp with this one I do not care
Thanks, and will do
You never know what the future holds...
Old 04-16-2014, 01:54 PM   #19
DravTech
Dravpnir's Avatar
Here is some pictures. The tie rod goes over the lower links, but under the drive shaft. I will decrease the caster one spline and then I should be able to remove the spacer I got between the steering arm and the rod ends on the tie rod.
Old 04-16-2014, 06:46 PM   #20
Very cool and nice mods on ur r1
Can't wait to see what's next...
noname0383 is offline   Reply With Quote
Dravpnir tries to build something all weather fun - Similar Threads
Dravpnir tries to build something small Dravpnir Losi Mini-Rock Crawler 221 11-10-2014 02:28 PM
Dravpnir tries to build something even lighter Dravpnir EnRoute Berg 88 08-03-2014 02:58 PM
Dravpnir tries to build something light Dravpnir EnRoute Berg 125 04-23-2014 06:01 AM
Chance of great weather this weekend leads to outdoor fun!! nics1152 Minnesota 5 11-07-2009 10:49 AM
