03-21-2015, 08:09 PM | #1 |
Newbie Join Date: Mar 2015 Location: EP
| My First Crawler R1
So guys i got the Gmade R1 kit as a gift that I requested because it just looked so awesome!! So while i waited i did some research on it and found it excelled in looks but not much else! I looked for all the different option parts and then found out that the gears in this thing were weak and ended up with the only thing that is still on it that is original is the axles and the cage, the upper links, the hardware for the links, steering rod, tie rod, rims, and the chassis. so as for the Gmade/Junfac/Other option parts: Aluminum Axle skids front and rear Aluminum Servo and battery axle mount front and rear 7 deg Aluminum Hubs front and rear Aluminum Knuckles front and rear Aluminum lower Link/Shock Mounts front and rear Aluminum Upper Link mounts front and rear High clearance lower links Carbon steel drive shafts Large battery mount/plate Delrin skid Rear Steer Kit (only used hardware and rods) Team Integy Axial Wraith Transmission with all steel gears and dig kit Gmade XD 103mm piggy backs Hot Bodies Rover Tire-Rock Crawler white dots Proline racing 2.2 2 stage rock crawling memory foam Aluminum Body/Roof/Hood panels Shock Brace I think thats everything Mods: Steering mod tie rods bent to clear diff covers relocated body shock mounts Servos: Savox SC-0254 for dig Savox SC-1256TG Steering Motor/ESC/BEC: Castle Creations 4000kV 4-pole Castle Creations Mamba Max Pro Castle Creation Basic BEC 10Amp? TX/RX: Fly-Sky GT3C w/overkillRc hack Fly-Sky 6Ch i was running 2x E-flite 3s 1350mAh i parallel...TOO much power. i will be making custom battery mounts with more surface area over the axles and will be moving over to 2x Reaction 2s 4000mAh i will edit this post again to link the steering mod thread and the Articulation thread Enjoy! Last edited by Benito; 03-21-2015 at 10:01 PM. |
05-10-2015, 04:07 PM | #2 |
Newbie Join Date: Jul 2014 Location: what are you a stalker
| Re: My First Crawler R1
is that an non sensored motor i spot if you are planning on running on rocks i would suggest running a tekin roc 412
05-10-2015, 06:18 PM | #3 |
Quarry Creeper Join Date: Feb 2015 Location: Australia
Great looking crawler you have there amigo, looks good. The battery you have on the front axle would be great for run time, but you'll find once you start going on steep inclines, there will be too much weight there. I've noticed the difference between the rig being too heavy overall and too much weight over the front axle, but great work on the lipo and servo mount's, looking good. |
05-10-2015, 07:49 PM | #4 | ||
did some more mods Swapped out my 103mm gmade piggy backs for some HPI Savage big bore shocks Attachment 315152 Attachment 315153 Attachment 315154 made a custom battery and servo mounting plate for the front and the rear. Attachment 315155 Attachment 315156 Attachment 315157 Attachment 315158 i had to either shorten my upper links or stretch my lower links to make the battery and servo plate work, i stretched the lowers. Attachment 315159 Attachment 315160 Attachment 315161 Quote:
like i mentioned i swapped out the motor for a roc 412, i added the JunFac CV joints on all four corners, added the JunFac wheel spacers, and swapped wheels for some all aluminum Integy wheels, i also swapped the draglink to give me more steering. EDIT: i also had to address the drive shaft issue! by stretching it i had to combine the rear female half and front male to make a drive shaft long enough. needless to say i had to buy another set of driveshafts to get another working drive shaft. Last edited by THX_138; 10-04-2016 at 11:41 PM. | ||
05-11-2015, 05:21 AM | #5 |
Newbie Join Date: Jun 2012 Location: kalispell
Very nice. I really like my r1 too but struggling with getting the suspension smooth.and some articulation out of it. Was looking at your pics and may be stealing a few ideas.
05-11-2015, 07:03 PM | #6 |
gota love the roc motors good torque and speed for the cash and i love the looks also how well does the fws work i've been looking into it as i stretched the wheel base on mine almost 2 inches to make a tow rig also i recommend running car oil in the diffs as i have found it reduces wear on the locker and pinion tee hee i am also running a tekin 27.5 turn gen 2 on 4s so i shred through gears Last edited by gr1; 05-11-2015 at 07:06 PM. |
05-12-2015, 08:23 PM | #7 | |
| Re: My First Crawler R1 Quote:
For the cash? i would hope so, its not a bargain motor, its top of the line, you get what you pay for. as for the 4ws it is pretty BA, it is an improvement over the stock steering but it still turns like poop even with the mods done to the steering knuckles/draglink/cv joints , but it is neat to have. i dont know what radio system you have but my Flysky GT3C with the hack and 6ch radio is working great. how did you come on that, you have got me curious? why not actual diff fluid? how do you keep it from seeping out the axles? i fortunately haven't ripped any gears but i broke a CV joint, that i have yet to replace. | |
Tags |
4ws, dig, gmade r1, wraith transmission |
My First Crawler R1 - Similar Threads | ||||
** Crawler Innovations ** 8 x 8 Crawler Hauler * continuing build thread; pic heavy | Nova's Ark | Multi Axle Rigs | 50 | 11-30-2019 10:02 AM |
Losi Micro Crawler Crawler-X SMC Plus Chassis Plus A Ton Of Stuff See Video | stomper4x4.com | Losi Micro-Rock Crawler | 5 | 05-14-2012 01:31 AM |
