Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: How low can you gear an r1?
Old 08-12-2015, 09:30 AM   #1
Default How low can you gear an r1?
I picked up a gmade r1, im getting ready to take out the rooster crawler for a mamba max to run 3s and i want to gear as low as possible. I picked up a 10t pinion and a 55turn novak motor. Following the volt up gear down train of thought im trying to gear as low as possible. Im trying to find tranny gears to gear even lower. Any Ideas?
Sent from my SCH-S738C using Tapatalk
envious8420 is offline   Reply With Quote
Old 08-12-2015, 09:51 AM   #2
Default Re: How low can you gear an r1?
Not about what you're asking, but,....you will need to keep an eye on the portal gears. They are not hardened material. They are not strong and will sheer/grind if you put too much power on them.
offroadace is offline   Reply With Quote
Old 08-12-2015, 10:13 AM   #3
I picked up spares for all the gears in both axles as well as new bearings. Im just trying to get the wheel speed back down some. Its pulling wheelies right now.
Old 08-12-2015, 01:27 PM   #4
I want to run it on a 3s mamba max. So id like not to be pulling flip wheelies and all my lighting is 12v so 3s just makes more sense to me.
Old 08-12-2015, 03:25 PM   #5
Just trying to go bullet proof. Using the portal gears as a fuse/weak link.
How low can you gear an r1? - Similar Threads
AX10 shift kit or shifting from Low gear to High gear? legobrains Axial AX-10 Scorpion 19 10-27-2007 12:24 AM
1:18th Dove, and low low gear, step by step???? clodman General Crawlers 2 04-09-2006 06:03 PM
Low..Low gear Mod for 1/18th vader General Crawlers 3 04-06-2006 06:43 AM
the low down on the xtra low gear mod heeper40 General Crawlers 9 02-02-2006 12:35 PM
Nylint Low/LOW gear skerb Videos! 7 12-19-2005 02:17 PM
