04-11-2017, 06:38 AM | #21 |
| Re: Thinking about getting Komodo
I don't have a Komodo, but I love my two Sawbacks. I'm a big proponent of them. Just ask the guys in my little crawling group. I built mine two out of the box. One has been run for a couple of years with no breakages other than bent leaf springs.
04-11-2017, 11:09 AM | #22 | |
Pebble Pounder Join Date: Feb 2010 Location: Mpls
| Re: Thinking about getting Komodo Quote:
I have not ordered parts yet but will probably use rcrun.com as they are in the us. Cheers! | |
04-13-2017, 12:50 AM | #23 |
Rock Stacker Join Date: Dec 2016 Location: Smithville
Yeah, I would of bought both too!! I've only had mine a few weeks, but I did some testing over the weekend. It's the kit version, set up as the manual suggested. I made a few changes, first one and most noticeable, it needs low weight. I already had the g-made axle tubes in it, (I don't like doing to many changes at once, it's to hard to tell what worked). I'm testing tomorrow, the new wheels/tires with 2.75 oz. in each tire and I also changed my shocks (G-Transitions) to full droop. They had the long spring above the piston, short one below the piston. I removed the long spring all together and put the small spring above the piston w/30 wt oil. I'm not 100% if the G-Transtion shocks will droop properly, but I figured I would try the cheap way first. The stock setup is a good starting point, I don't think it will need much to work good, the bigger problem is the driver. An easy mod is the R1 gear mod, Jeepiac has a great how to thread in here, UD/OD make a huge difference. Last edited by mHoups; 04-13-2017 at 12:56 AM. |
04-13-2017, 08:26 PM | #24 |
Thx mHoups. I have an od/ud in 2 of my mini losi crawlers & love it. I'll try to find Jeepiac's post. Cheers! |
04-13-2017, 08:40 PM | #25 |
here is a link to Jeepiac's over drive/under drive posting for putting R1 gears in front axle of Komodo. Thx to mHoups & Jeepiac. Overdrive your sawback R1 gear set $8.10 http://www.junfac.com/shop/index.php...roducts_id=284 Cheers! Last edited by Snipervision; 04-13-2017 at 08:48 PM. |
04-27-2017, 08:22 PM | #26 |
Anyone have a suggestion for brushed motor? Was thinking HH 35t 540 crawlmaster TrailMaster Sport 540 - TrailMaster Series - Brushed Motors - Motors + Hobbywing Quicrun 1080P on 3S. Just thinking about spending a little more on motor but want to stick with brushed due to mud & water. Thoughts? Cheers! |
04-29-2017, 07:00 PM | #27 |
Quarry Creeper Join Date: Feb 2015 Location: Amongst the UTards
Komodo is a great scale rig. Have one and a Sawback. Of the 2 I'll take one of the 4 link setups like the Komodo any day. My SCX will out crawl both though. I am running 35T setups in both. Biggest issue I have is with the body dragging. Relocated battery to front. Broke the Junfac CVDs and am trying the GPM versions Everything else is reliable.
04-30-2017, 11:37 PM | #28 | |
BTW, how are your rigs coming along? | |
05-05-2017, 06:02 PM | #29 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
The aftermarket axle trusses are a worthwhile addition also. It seemed to give the suspension a little more flex. They also add a little bling to the axles.
05-05-2017, 07:01 PM | #30 |
Quarry Creeper Join Date: Dec 2016 Location: FL
I had the same issues with the Junfac Long CVD's and GPM same thing. Still have yet to find a fix for it. Hopefully mHoups idea will deal with the issue. Until than front axle is in disrepair though as I need to sell the vehicle I may just stick the dog bones back in and call it a day.
05-13-2017, 01:14 PM | #31 |
Went to a swap meet 2 weeks or so ago and bought another Losi Comp Crawler with dig & ready to rock so we now have 2 of same that can run in 2.2 sporty & 2.2 pro class. This ate up a little of my play money. Today I just ordered the following which I will add to my Kit Kmodo. Bought from Junfac & Amazon. 1 x Clamp Type Aluminum 12mm Wheel Hub (4) (10mm Thick) (GM70273) 1 x Aluminum Servo Plate for GS01 Axle (GM52123S) 1 x Aluminum Zero Ackerman Knuckle Arm (Silver) (2) (GM30003) 1 x Aluminum C-Hub Carrier (Silver) (2) for GS01 Axle (GM52120S) 1 x GS01 43mm bumper frame mount (J30004) 1 x Gmade 30004 Bent Front Steering Rods for Gma30003 Zero Ackerman Knuckle 1 x Gmade 52415 Rock Sliders 2 for Gs01 chassis Toy (for the RTR truck) 1 x Gmade 30031 GS01 Front Drive Long CVA Kit 2 for Komodo Wanted to order more but that is my limit for now. I'll post up once I get parts. Cheers! |
Thinking about getting Komodo - Similar Threads | ||||
Need Help with Komodo | Scionizer07 | G-Made Crawlers | 4 | 04-13-2016 09:48 PM |
Im thinking thinking about whats next...lol | buggynutt | Kyosho Crawlers | 6 | 03-08-2012 09:04 AM |
komodo 2.2 | bamaboy1992 | General Crawlers | 6 | 09-20-2011 10:03 PM |
Komodo | tutit | 1.9 Scale Rigs | 4 | 12-06-2009 06:04 PM |
